Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-23-2002, 09:36 PM
Aussie's Avatar
Aussie Aussie is offline
2.5Gallon Air Tank Mounted
Well I finally found a spot to put my air tank. I was just about to drill some holes in my sliders for air tanks and decided to try and find a spot for the tank one last time.
I ended up sliding the tank over the rear diff and installing it above the drive shaft between the fuel tank and muffler. There is about 2" to spare between the shaft and tank under full compression. The hardest part was trying to drill the holes in the right location. The holes must be drilled from below so I made a template but it was still a b...h.
Because of the closeness to the muffler, I was concerned about the tank heating up and the pressure increasing, so I also installed a pressure relief valve.
Using a QA2, it takes 2 minutes to fill up. All I need now are the lockers.
Shows where the holes were drilled. Tank resting on diff.
Note the larger holes drilled in the front so I could get a socket on top and align the hole with the tank.
Tank installed.
Air outlet on rear bumper.
Richard
Old 01-23-2002, 11:24 PM
ozxterra's Avatar
ozxterra ozxterra is offline
Nice pics!! Ive been stewing on a setup for my rig... they help.
Old 01-24-2002, 09:28 PM
Kennedy Kennedy is offline
Looks great...
Just a quick question...
Where's the QA2?
I'm looking at a similar setup, but can't figure out what to with the QA2...
Old 01-25-2002, 07:16 AM
Aussie's Avatar
In the engine bay, passenger side near the firewall. I had to move some stuff around and make up some brackets. I will post some photos tomorrow.
Richard
Old 01-27-2002, 10:26 AM
What would you thinkof mountinh the pump under the body?
I've found a spot on the frame rails... but woulld corrosion and such be too much for it? Thoughts?
Got any pics of your setup Aussie?
Old 01-27-2002, 02:10 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
I'd be more concerned about the pump trying to suck in the crud that gets kicked up at/on it. You'll be changing that intake filter pretty often I'd say.
Brent
Old 01-27-2002, 07:06 PM
Aussie's Avatar
I agree with OffroadX, it would be too easy to get crap into it. A compressor can get hydro lock as well. Also there is a good chance of bouncing it on a rock, and rocks usually win.
Here are some photos of my QA2 install. My was actually a portable that I hard mounted. I moved the alarm horn and made up some brackets to mount it.
Richard
Cam '96 4-cyl 2.2 5sfe: coolant reservoir lowfluid sensor Maulana Camry/Camry Hybrid/Vista 0 03-19-2010 09:14 PM
Air tank abcgraphix Car Modeling 6 01-08-2005 06:05 AM
Homemade Air tank kinetic Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 07-01-2003 12:43 PM
Air tank for airbrushing MaukaRunner Car Modeling 2 11-13-2002 08:10 PM
EOE Sliders as air tanks Aussie Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 32 01-10-2002 01:32 PM
