Old 12-08-2004, 01:38 PM
abcgraphix abcgraphix is offline
Air tank
A friend of mine has an airbrush compressor (I think it is a badger 80-2 or a paasche d500) and I was wondering if it is possible to take a 7-10 gallon air tank and fill using the airbrush compressor.
Do you think it would work? How long should it take to do so?
Thanks
Old 12-08-2004, 02:38 PM
Vric's Avatar
Vric Vric is offline
Re: Air tank
yes it should work, but you will need an air regulator and probably a moisture trap. I used that before getting a real compressor.
7-10 gallon should last a while ! (2gal is fine for a body + all the cleaning after)
Old 12-08-2004, 07:22 PM
008's Avatar
008 008 is offline
Re: Air tank
Airbrush compressors are only rated up to a point where most airbrushes require. I don't think a d500 will push more than 30psi. 30 psi in a tank won't last you very long, whether it's 7 or 70 gallons. You could keep the pump running to keep the tank full but that defeats the purpose.
You're better off buying the right fittings and filling the tank at a gas station. You could also just use the D500 the way it was meant to be; nothing wrong with that.
Old 12-08-2004, 09:02 PM
Vric's Avatar
Re: Air tank
I had a cheap compressor for tires. cost 7$ and it was able to fill a 4Gal tank with 90psi.
Old 12-08-2004, 11:00 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
ABCGRAPHIXS...
yeah the D500 will only push 28psi and cant fill a tank to its limit which is why i told you in the PM that i fill my 5 gallon at a gas station. what i failed to tell you is that you need to fit your tank with a Shreider valve. like on bike tires or car tires. about $10 or so. sorry i forgot this!?!
Old 12-09-2004, 06:48 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Air tank
Nope, it wont work. It will ruin the compressor too.
-Mike
Old 01-08-2005, 06:05 AM
resinboy2040 resinboy2040 is offline
Re: Air tank
what types fittings would i need for a tank if i want to fill it up at a gas stasion????
atm all i got is my badger cheapo airbrush, paints,thinner...,and one of those @*$%%^ aircans
