Old 11-13-2002, 02:27 PM
MaukaRunner MaukaRunner is offline
Send a message via AIM to MaukaRunner
Air tank for airbrushing
I noticed a lot of airbrushing posts.
Does anyone use a air tank for airbrushing? They are the ones used for filling tires. Sorta looks like a compressor tank except without the compressor on it.
I had one when I bought my airbrush in the early '90's but the tank had a expiration date and had to be thrown away.
The best part of it was it held enough air to spray a model. It could go up to 100 psi. The bad part is you need a compressor to fill it.
You might want to consider it since it only costs about $20, is silent, and can be regulated.
Sorry if it's been mentioned before but I did a search and haven't seen anything on it.
Old 11-13-2002, 03:05 PM
Vric's Avatar
Vric Vric is offline
I use a Propane Tank (like on bbk)
I put 100psi but I can go more..
cheap solution, quiet while you are working (you fill the tank before) and 100psi il ok for 1 or 2 model..
get a cheap compressor for tire (15$) and some adaptor to get fit the airbrush with the tank and it's done...
oh and you need an air regulator (or you will get 100psi... a bit too much for painting hahaha).. 15$
Old 11-13-2002, 08:10 PM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
i use a 9 gallon air tank hooked up to a 2hp industrial compressor, i bougt both units seperately. it works great, its totally silent and it only takes me a few mins to fill up the tank which last for hours, mine holds up to 125psi. but the reason why i choose this setup was so that later on i can use for air tools as well.
Help with my air compressor and airbrushing. D_LaMz Car Modeling 16 01-07-2006 05:06 PM
Spray-Work Basic Air Compressor w/ Airbrush smb Car Modeling 3 04-27-2005 09:15 AM
Homemade Air tank kinetic Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 07-01-2003 12:43 PM
2.5Gallon Air Tank Mounted Aussie Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 01-27-2002 07:06 PM
EOE Sliders as air tanks Aussie Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 32 01-10-2002 01:32 PM
