Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-16-2002, 06:33 PM
pimpin96se pimpin96se is offline
does your max drift left/right ???
yea i'm tryin to figure out if anybody has the same problem as me.when i'm on the highway i have trouble stabilizing the car.it either goes left or right.i got an alignment twice just to make sure and it didn't go away.tire pressure is at 32,and i got the stock shock on at 60000 miles on the meter.do i need new shocks????????????????????:smoka: :smoka: :smoka: :smoka: :smoka: :smoka: :smoka: :smoka: :smoka: :smoka: :smoka: :smoka:
chi-town maxima 1996 se white
Old 01-17-2002, 04:55 PM
Ravq Ravq is offline
There was an old practice alot of the tire shops used to do but don't do so much nowadays called "trueing". It's where they can shave the tire tread to make the tire closer to round. You may consider that. And since you've had an alignment done 2x I suggest you also check to see if you don't have a sticking caliper. You can do so by feeling the wheels after a drive. If one feels hotter than the others then that may be your culprit.
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
Old 01-18-2002, 02:47 PM
Nizmolee Nizmolee is offline
Send a message via AIM to Nizmolee
mine goes to the right a little bit.
98 Auto NOS Maxima.
Old 01-21-2002, 08:49 AM
NJMAXSELTD NJMAXSELTD is offline
Drifting left/right
Are you on stock springs or lowering springs? If your on stock springs tell the alignment shop to pull as much EVEN negative camber as possible. By EVEN I mean the same on both sides. Some shops like to set up camber at 0 to -.5 degrees. Thats factory specs. If you run a little more camber, about -.8 degrees your drifting will stop. Your turns will fell a bit tighter too.
Also what kind of tire are you running? A more agressive tire will track better. If you have a soft crusing tire on there you will have more of that floaty feel.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 01-24-2002, 03:41 PM
yea i got stock springs with 65000 miles.i was considering a new suspension anyways. i got the yokohamas H4"s , there kinda loud on the highway,but i will look into that camber as soon as i get a chance.i was thinking about taking it to a nissan dealership for that since they would know best.:ylsuper :ylsuper :ylsuper :ylsuper :ylsuper :ylsuper :stormzap:
Old 02-01-2002, 06:13 PM
samabra samabra is offline
My Maxima was having the same problem, I had the tires changed once, rotated twice, and realigned once, and nohting seemed to help. Finally I took it to a huy who specializes in Maximas, and he first said he thought that it was the steering column, but it turned out to be some loose bolts on the camber. Cost me $90 to have repaired.
Old 02-01-2002, 08:23 PM
bobo_80 bobo_80 is offline
Exclamation
mine drifts to the right.......when i let go of the wheel....and brake and gas.....it drifts right in these 3 situations
Old 03-24-2002, 01:56 PM
95maxSE 95maxSE is offline
Banned
drifts?
I have the same problem ,mine drifts the opposite way on turns...i got stock shocks and pirelli tires:smoka: :bandit:
Old 03-25-2002, 10:42 AM
Look, this seems to be a very common problem. The woman who owned the car before me got new tires, several alignments, had it in to the dealership, etc and never found the problem. She disclosed it when she sold it to me. The car pulled right especially when pulling out from a stop, or when braking. I took it to a specialist guy in this area who is known for honesty. He had the car for 3 days. First he thought it was the rack, and that it needed to be replaced for about $800. However he continued testing. He found after three days of testing that bolts on the rack were loose and causing the problem. The repair was $90, 5 months ago and I haven't had a single problem since. Make sure you don't get fleeced.
Old 10-19-2003, 06:42 PM
lestyle lestyle is offline
Shock replacement
i had my car run with 80k and looks like it's time to replace the shock. ANY suggestions i can get a good replacement and is that easy to install. just wanna save some money spent in Dealer chop shop.
Old 01-07-2004, 12:28 PM
Maxaholic Maxaholic is offline
Re: Shock replacement
The right/left drift issue that everyone seems to be facing is due to caster differences between the left and right side. Since our 5th gens don't have an adjustment for caster it can't be fixed without elongating the holes at the bottom of the struts to be able to make the adjustment. I had the same problem with my car until I had the holes elongated to facilitate caster adjustment. The cars now rides perfect.
Old 01-07-2004, 01:27 PM
chrisr67's Avatar
chrisr67 chrisr67 is offline
drove from Ft.Lauderdale FL to Hot Springs Ark over the Christmas holiday and didn't notice any drift problem like the one you're describing. My 03 Max ran perfectly all the way up and back. Except for an alan wrench that gave me a flat coming through Pensecola ( damn I hate those tiny donut tires they give you!) Anyways, plugged it myself and was good to go in no time. I was surprised I got 37.6 miles to the gallon with the cruise set on 60 for about 230 miles! However my average was around 28mpg which still isn't too bad since I was doing 85-90 the majority of the trip.
Happy New Year everyone!
Old 01-07-2004, 11:02 PM
Ceasars Chariot Ceasars Chariot is offline
me 2
for a while my max was doing the same pulling to the right. an alignment was not helping had 3 with no sucess. lowered the car with new shocks and springs, still didnt help, put on new tires ( radial pull) still didnt help. then later on I had something done called a toe in. i believe that is what helped, i dont notice a thing.
97 Nissan Maxima (NA with USIM) - [email protected] mph
97 Nissan Pulsar SRV VZR (stock) - [email protected] mph
Old 01-13-2004, 11:09 PM
skids929 skids929 is offline
I have this same F-n problem on my 98 Max SE, and it only has 28,000 miles! What a stupid set of problems these cars have. I mean who designs a car and puts into production a car that CLEARLY pulls to the right? Nissan's quality control in the late 90's definately leaves something to be desired, this problem is simply unacceptable. I was going to get mine aligned tomorrow but now I gotta call around to 600 places to find someone who is familiar with this and can fix it efectively, before I waste $70 on a alignment the car really doesn't need. Uuhhhgh! I am used to Hondas, drive straight as an arrow and never have these quirky,nettlesome problems.
Old 01-14-2004, 12:40 PM
Spaz Spaz is offline
Re: does your max drift left/right ???
Heh, I'd rather keep watch on my tire pressure with the max than have to get out and push up to speed with a honda.
'99 Drifts Left Even After Alignment phoenixg127 Malibu 2 08-12-2006 02:46 PM
Hey This would be a good , but rare drift car...right? Supra_Touge Celica 17 09-17-2004 10:18 AM
What is your favourite D1 car and what would be your dream Drift car? BOOSTD Drifting 51 11-03-2003 09:41 PM
Econometer gauge is going left-right all the time on E30 dojchin 3 Series 0 09-02-2003 10:09 AM
What car gave your Max your best race? 2001 AE Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 77 11-20-2001 02:32 PM
