Old 05-12-2004, 10:56 AM
OzZySi's Avatar
OzZySi OzZySi is offline
Red face Alcad II question
Hi everybody!
I recently purchased Alcad II in a spray can- and I am VERY pleased with the finish it gives me. I had One major problem though- the chrome rubs off VERY easily.
Now, I'm thinking a problem could be that I used tamiya's black as a base color instead of a water based black like it tells you to. Would that make the difference?
~OzZySi
"It's better to be a living dog than a dead lion"
Old 05-12-2004, 11:06 AM
freakray freakray is offline
AF Modelrater
Re: Alcad II question
Which Tamiya black did you use, the enamel, the acrylic or the lacquer?
AF User Guidelines
Old 05-12-2004, 11:09 AM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
Originally Posted by OzZySi
Hi everybody!
it says you should use alcadII black undercoat.
Old 05-12-2004, 11:25 AM
GT-Alex's Avatar
GT-Alex GT-Alex is offline
Send a message via MSN to GT-Alex
enamel black undercoat.
Old 05-12-2004, 11:30 AM
OzZySi's Avatar
Re: Re: Alcad II question
"Back Alcad II with waterbase black paint basecoat"
I'm not sure what kind of paint tamiya is, now that you mention it... it's the stuff in the little spray cans.
~OzZySi
Old 05-12-2004, 12:18 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Wow.. didn't know Alcad II came in rattle cans.
Steve a.k.a. Hiroboy
Old 05-12-2004, 12:58 PM
AF Modelrater
Re: Re: Re: Alcad II question
The stuff in the spray cans is synthetic lacquer, Tamiya also makes acrylics and enamels in bottles.
AF User Guidelines
Old 05-12-2004, 01:08 PM
supermod04's Avatar
Banned
best bet is to just get alcallad 2 black base
Old 05-12-2004, 01:12 PM
ZoomZoomMX-5's Avatar
If you want Alclad II chrome to stick, you have a few choices that work.
It will not stick to dried water based acrylics, or lacquers.
It will stick to dried black enamel.
It also will stick to wet enamel, and wet Tamiya TS spray.
I've heard it does not stick well to Alclad's own black base. Go figure.
I had similar results w/Alclad over Tamiya TS black...beautiful, but couldn't touch it. I tried it over freshly airbrushed Testors black enamel, and it's beautiful and permanent. Veyron has had permanent results spraying it over freshly sprayed TS black...just don't let it dry, the Alclad will not "bite" into the surface to make it permanent.
My Fotki Album
Old 05-12-2004, 01:43 PM
labandabonnot's Avatar
labandabonnot labandabonnot is offline
Very usefull thread! Should been added to the "how to" - paint section!
Back to life soon...
Old 05-12-2004, 03:59 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
From what I understand. People back there Alclad using Testors Black enamel. Try that out colin.
-Mike
Old 05-12-2004, 08:38 PM
OzZySi's Avatar
Will do, Mike-o!
Thanks for all your help guys. I'm not an air-brusher, so i'll try some of the other meathods. If the wet TS black doesn't work, i'll try Testors.
Edit: I've gotten some requests for a picture of the rattle can, since they are apparently something more special than the bottles.
I took pics of my project RX-7 with the alcad can in the back for people who want to see it.
~OzZySi
Old 05-12-2004, 10:09 PM
scaleracecars scaleracecars is offline
Hi everybody!
You are using material for Lexan designed to adhere to clear lexan then have a black acrylic overcoat placed on it. You need to get regular Alcald II paints where you place the black first and the Alclad second.
David
http://www.scaleracecars.com
Old 05-13-2004, 08:08 PM
minniebanister minniebanister is offline
To clarify David's comment a little. RC cars made of Lexan are painted on the inside of the body. So, when the car gets bashed, the paint doesn't chip off. The Alclad is safely sandwiched between the Lexan and the black overcoat. In our hobby, we paint the outside of the body. The Alclad is on top where you can touch it. It's not surprising that the stuff made for Lexan rubs off when we use it.
Old 05-14-2004, 10:56 AM
OzZySi's Avatar
Ooooooh, I get it now... Oh well, that sucks.
~OzZySi
