Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 05-11-2004, 01:50 PM
blight blight is offline
Cheep?
What do you think would be the cheepest car to be a 10 to 12 second car? What would you pick, why? What would you do to it, why? How much would the car cost? How much would the upgrades cost?
________________
I don't care of imports vs american cars only on performance.
Old 05-11-2004, 05:18 PM
nacho_nissan nacho_nissan is offline
Send a message via AIM to nacho_nissan Send a message via MSN to nacho_nissan Send a message via Yahoo to nacho_nissan
Re: Cheep?
to run 10's! the best choice if you have a low budget is to get a 5.0 mustang. gte one for under $4k and with a few things, youll be in the 10's. maybe $5k of mods will have you running 10's. i dont know much about domestics, but i think its a good guess. or if you have money... you can get ANY car into the 12's, and if you have a bit more, any car into the 10's.
Old 05-11-2004, 05:28 PM
phlygirl1437 phlygirl1437 is offline
Re: Cheep?
IMO an LT1 Camaro. The 5.0 'stang is a good choice also.
1993-1997 Camaro Z28's can be had anywhere from $4k to $8k, depending on the mileage and the condition of the car.
I can hook you up with someone who has both a 5.0 'stang and an Z28, both of which kick some major ass on the drag strip. He can give you a more detailed explanation on how much it would cost to get the cars into the 10's.
"I used to have a handle on life, but then it broke off..."
Old 05-11-2004, 05:42 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
No question, a Turbo Dodge or a Turbo Chrysler. Chances are that you won't pay more than $3,000 for a good condition one. Then, all you have to do is put about $1,200 in the car and you're easily in the 12s. I don't know of many cars that provide the speed these do for so little cash. In fact, I am flying out to Ohio to buy one with only 74,000 miles on it and it is in mint condition except for a dent in the driver’s side quarter panel. The guy only wants $600 for it. Then for around $1,200 I could be in the 12s. That is a mere $2,000 to run in the 12s and they will do it all day long without a complaint, they’re rock solid.
Old 05-12-2004, 12:39 AM
Demon_Mustang's Avatar
Demon_Mustang Demon_Mustang is offline
I can only really vouch for what I know, and that is the 5.0 foxbody Mustang. You can easily find a good condition one for less than $4000, if you want it for speed only, get the LX, but NOT the convertible. The LX is lighter than the GT, and is actually faster than the GT when stock because of the weight. A couple grand will get you into the 12's and 10's fairly easily. You could get a smaller engine car to do the same, but the higher revs would decrease the life of many parts of the engine, including requiring an engine overhaul a tad mroe often than you would need in a 302cid V8. You can get a 1988 (that's 16 years old) LX Mustang for cheap and the engine will still be a long ways from breaking down, they have nice strong engines.
I've never owned a Camaro before, but from what I've heard, they are about the same with Mustangs in terms of having a nice strong engine to work on. And aftermarket parts are easy to find and are also very cheap. They are also just about the easiest engines to work on.
Old 05-12-2004, 12:55 AM
Janet Reno Janet Reno is offline
Here's an article I found on DSM's and getting them into the 12's while nearly stock.
"how to run 12's on a close to stock 1g awd....
written by: peregrine
Currently Offline DSMtuners Member
Car: 90 Eclipse GSX
over the last couple of years, ive done nothing but read and talk to fellow dsmers and ive come to the conclusion that a few well chosen parts will put these (awd) cars into the 12 EASILY. i took the initiative and put my money where my mouth is. my part list is as follows. full 3" o2 eliminator exhaust (you can also drop the exhaust after the stock downpipe but its loud and your gonna buy exhaust anyway), k&n with no air can, MBC, taylor 8mm wires, bpr7es', 190 fuel pump ,afc (old or new style). i bought all this stuff USED off the trader for under $700. nothing is ported on my car so ill leave it up to you as an individual if you want to jump into the porting. this is a bare bones list to run 12s i think (safely). you might be able to pull it off with out an afc or fuel pump or plug wires but will you be driving home? buy some 114 race gas (make sure your not running a cat, leaded fuel will kill your cat sooner than later) crank the boost to 20 psi and voila!! hauling ass! of course all this is pointless if your car is in poor running condition. a basic tune up and compression test will give you the peace of mind to drive the shit out of the car. lower your tire pressure to 20psi in the front and 18psi in the rear. when your pre staged theres a trick you can do to help you shift smoothly. shift from 1st to 2nd to 3rd to 2nd to 1st a few times and it helps line up your synchros for some quick shifting. rev the motor to 5500 and dump the clutch and dont miss second!! that will set you up for a blazing run that will most likely net you that 12 sec pass. if you dont do it your first try dont give up!!! "feel" your way around your cars power band and try shifting at different rpm points. youll soon discover where your cars sweet spots are and youll have many a person scratching their heads as to why a basically stock awd just did the impossible. let your car cool down between runs as your stock intercooler will heat soak and you WILL lose timing, even with race gas. hot lapping the car is also detrimental to the stock clutch. cooling it down for 20-30 minutes between runs ensures optimal performance from your stock parts. hope this helps some of you to reach your goals wothout killing your wallet. "
http://www.dsmtuners.com/forums/showthread.php?t=60008
Old 05-12-2004, 02:22 AM
Oh man, I don't think I can rev the engine to 5500rpm before releasing the clutch, I'd be too afraid to screw up my tranny... I'm a wussy, I know!
Old 05-12-2004, 07:37 AM
From my understanding though crysler, mitsu, dodge, ect. have junk tranys. Though I heard that there is ONE that is bullet.
I think that I found what I am looking for now.
86' vette: 3500
Chip: 2000
Cam: 350
K&N air filter:350
total: 6150
I know a friends of a friend who is running 11.5s with only this done to the the vette. He did not even have slicks just regular crappy street tires. Plus the car out-handles 911s!
Old 05-12-2004, 09:56 AM
Polygon's Avatar
The Red Baron
Re: Cheep?
The A-604 was junk, and that was one tranny. The A-555 and A-568 from Chrysler were forged five speed manuals. They were designed by Chrysler and built by Getrag of Germany. Trust me, they hold up. Even the non-forged A-520 and A-525 and even the auto A-413 can take a good amount of power with very little modification.
Old 05-12-2004, 10:07 AM
Re: Re: Cheep?
I'll look into that -so anyway what do you think of the vette plan?
Old 05-12-2004, 11:31 AM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
Re: Cheep?
how many damn forums are you going to post this in?
seriously dude.
at least you found a good forum to post it in...
again.
Old 05-13-2004, 07:33 AM
Well I as I said I think I found what I am looking for, the vette thing. Though I am not sure what cam or cip I want to throw in it.
Do any of you have suggestions?
Old 05-13-2004, 09:29 PM
dayna240sx's Avatar
dayna240sx dayna240sx is offline
Banned
Send a message via AIM to dayna240sx
Re: Cheep?
I could easily get an rx-7 in the 12's for under $2000 if you know what you're doing. That's including the price of the car.
Old 05-13-2004, 10:21 PM
Yah, too bad that bloak that tried to race me on the highway with a RX-7 didn't know your tricks... Too bad for him at least, lol.
He did have about 500 stickers on his car, you would have thought with so much stickercharging that it would have been flying.
Old 05-13-2004, 10:33 PM
Re: Cheep?
its ok when people rice out econoboxes(civics), but rice out a japanese muscle??? makes me mad!
