Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 01-12-2002, 11:58 PM
P10Skin P10Skin is offline
Door Subs
Hi Guys
I have 2 8inch subs sitting in my garage and was wondeirng if it would be a good idea to build a fibreglass kick panel and stick them in the front doors? I have 6x9's in the rear tray and 2 ports for a 15in sub in the boot! the tweeters in the stock postion have been replaced and if I go ahead with it I will proberly mount 6.5's at the bottom of the a pillar.
Cheers
John
http://www.nzprimeracarclub.cjb.net
Old 01-13-2002, 02:49 AM
cliffud's Avatar
cliffud cliffud is offline
Send a message via ICQ to cliffud
8 inch subs in the doors???????
ok- uhhhhh- not to burst your bubble-
but you probably won't be able to 8 inch subs into your doors because of the weight factor... they are pretty heavy speakers and for you to put them resting on a fiberglass mount on the door??? hwoa- it would be quite impressive if you could do that... however it would be very heavy- and for you to not have any intrusion into the cabin (the cabin is small enough already ) you would have to sink the sub into the door a bit- which might interfere with your window.
second of all- where are you going to put a 6.5 in your a pillar??? the a-pillar isn't even 6.5 inches big.
i've read up on a lot of car stereo mags and i've taken apart almost everything under the dash- my suggestion would be this- install a fiberglass custom mount on the door for the 6.5s and then put your tweeter back into your a-pillar or wherever you pulled it from- and then make a custom sub enclosure to fit at the very very very back of the footwell- so it will almost be invisible from the passenger.... u probably can't put a sub on the left side- due to the pedals and stuff- so you might want to just make one good box with a port that shoots to the left side BEHIND the center console... this will kinda make the bass seem like it's more centered and equal for both passengers...
hope this helps- i didn't see anyone else reply to this post so i thought i would since i've torn the carpet apart before...
cliff.
www.clearbrafilms.com
Old 01-13-2002, 02:56 AM
Well thanks for ur replie. The tweeters are still in the stock postion just replaced with decent ones and I was planning on placing the 6.5 in fibreglass pods at the base of the A pillier(ie where it connects to the dash) I agree with the too havey bit so I will sscrap that idea I just saw a few SQ cars with a set up similar to wot I was planing and it got me thinking!
Old 01-13-2002, 03:15 AM
cliffud's Avatar
cool dood.
hope it all works out man...
if u get those pods working- show me a pic- i might be interested in learning how to do all that "make a pod" thing..
c.
Old 01-13-2002, 04:12 AM
Will do I gotta buy some resin in the next few days then rip the doors out and have a look and ill let u know from there. buildign them isnt hard so ill try get sum pics of the process for you!
Thanks for your input man
John
Old 01-13-2002, 03:08 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Guys...dont forget that its also not all about speaker size but placement is very important.
You can tell this by the sound boucing off the windows at the right angle...like when you open and close your windows you can tell a difference...of course, this doesnt apply to subs...but to mids and tweets.
-Brian Jones
I got a snake man
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
2002 Alero door question: Grand Am doors? cjtskater1 Alero 2 09-09-2010 11:04 PM
Rear Doors Won't Open bdzb1234 Econoline 2 05-06-2010 10:34 PM
Why does my driver side door still rattle over bumps? jberenyi Suburban 0 03-12-2009 08:52 AM
exterior door moulding driving me crazy chilton2001 Non-Performance 0 02-17-2009 02:17 PM
