Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-06-2001, 03:06 AM
ThA_KwAK ThA_KwAK is offline
How may i place COLORED LED'S in the car such as the dome light and the door lights?
I would love to know how to wire the LED's...i have LED's and I have resistors...what should i do?
Old 05-06-2001, 02:01 PM
bobo_80 bobo_80 is offline
Red face humm........!!!!!!
well......let me think....i think the bulbs in the car are all under 4.8V...i`m not sure...it`s either that or 12V..
..anyways check the voltage with a voltmeter...when u put in the resisters make sure the voltage doesn't go over 6V on the LED's in parallel..........
....parallel is when u got more then one LEDs and connect them in a + to + and - to -
.......don't connect them in + to -......cuz u`ll waste a lot of electric and the LEDs are gonna be really dim...!!
Old 05-06-2001, 02:06 PM
Exclamation wait.....
dun't forget the legs on the LEDs.....the longer is the positive and the shorter one is negative.......
.......and depending how many LEDs you want in one time, alwayse wire the LEDs in + to + and - to -...
....then connect it on the source.......
....about the source....the LEDs wont light if it`s got the wrong + or - side so just play with it switching the side where it's gonna connect to the source........
...and resisters you can put on either side of the LEDs..
Old 05-07-2001, 08:12 AM
GarySE95 GarySE95 is offline
Lightbulb alternative LEDs
Go to the Maxima.org website forums... there have been a few postings about replacement of LEDs. It's very do-able. Got mine looking great.
The first major trick is keeping the +/- connectors matching. Easiest way is to note how the metal inside the diode is shaped. Usually it points to the positive side. Once you got this figured out, it's easy to tell which is which when you clip the leads (you'll have to, for fitting purposes). Just make sure you remember which sockets in the board are +/-!
For the rest of it, you'll need dexterity in soldering, especially when doing the driver's door.
Gary
95 SE 5 speed, charcoal leather, all options (except c/w pkg), AE shift knob, walnut dash overlay (Joshua Tree), Diamond Cut clear bumper lenses, Xenon 9004 HID, Blue/Yellow/Green interior LED's, 100k+ miles; To come: Clear/Red tails, FSTB, RSTB, Polarg gauge bulbs, Strobes, K&N, exhaust
Should I change the color of my car???? spyderturbo007 Off-Topic 12 03-12-2004 12:30 PM
the colors dood the colors.... mrgofast218 '88 - '91 Civic | CRX | Wagon | Shuttlee 13 03-09-2004 12:18 PM
I've got the colors, I just need the cars. Bimmerkid Car Modeling 4 03-15-2003 12:50 PM
How do you change the car color? LynxMS Graphic Manipulation 4 11-25-2001 01:07 PM
