Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-15-2004, 11:24 AM
norseman norseman is offline
Aurora turn signal problem
I am having problems with both left and right turn signals. When I turn, the turn signal does not turn on inside the car and don't indicate outside the car. I have replaced the flasher underneath the dash but that fixed my emergency flasher situation only. Owners manual says to check the fuse and turning light bulbs but I'm afraid it might be the multi function switch which is over $400. Does anyone have any suggestions on how to fix this? Thanks, Norseman
Old 04-15-2004, 11:27 AM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
Re: Aurora turn signal problem
im having probs too, only my left flasher works, but the hazards work, and all the bulbs work too. Im baffled,
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 04-16-2004, 10:10 AM
Silverbullet97, could be just one of your lights (that does not flash), possibly your fuses need to be checked or the multi function switch. Let me know how it goes...I'm curious
Old 04-17-2004, 10:26 AM
All, I called about 10 Olds dealers throughout the nation and picked the service depts. brains to finally learn that there are TWO flashers under the steering column; one for emergency and one for turning signals. Found the second flasher tucked up further and replaced it and it works great.
Old 04-17-2004, 05:10 PM
madcatter madcatter is offline
I don't know about other manufacturers but GM loves 2 flashers. When you smoke a signal bulb, the flashers stay on high on that side when you flip the switch. Could be a problem if you get stranded on the road and need 4-ways but the bad bulb won't let them work. Hence, the seperate flashers. My '90 Chevy truck is that way too so keep that in mind, there's a lot of difference between vehicles there.
Old 01-04-2005, 12:27 AM
jagchick's Avatar
jagchick jagchick is offline
Send a message via AIM to jagchick
How much are those two flashers under the steering column and how hard and costly are they to replace? My turn signals have slowly and then rapidly gone kaput.
02 Windstar - turn signal problem ethanaw Windstar 12 07-02-2016 10:40 PM
04 Saturn Vue - turn signal keeps clicking even when there's no signal on richter343 Vue 4 07-19-2010 06:20 PM
turn signal right - sometimes KronVickan Crown Victoria 6 01-29-2010 02:14 PM
turn signal lights not working x3mtm Durango 4 01-11-2010 12:49 PM
1995 Aurora Turn Signal Relay Catherine Probeck Aurora 4 11-07-2003 02:13 PM
