Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-15-2004, 07:25 AM
Powder Powder is offline
Unhappy 99 Ram 1500 Oil Problem
I have a '99 Dodge Ram 1500 that I am having a problem w/. It is full fo oil, but whenever I stop or make a turn, the oil pressure light comes on and my pressure drops to nill for just a second and then pops back up. The truck makes no engine noises when this happens. Need some help. I think it may be my oil sending unit.
-Powder
Old 04-15-2004, 07:59 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 99 Ram 1500 Oil Problem
Perhaps the PCV valve is bad. Change it and see what happens. It's worth the trouble.
Old 04-23-2004, 04:19 PM
sgtsilvio sgtsilvio is offline
-Powder
I had the same problem with my 2001 1500 2 WD. Then abruptly lost all oil pressure while driving on the interstate. Turns out that my oil pump pick up was clogged with gunk. For about sixty bucks I replaced the pump, cleaned the pick up tube filter and replaced the oil pan gasket. Turned out to be a pretty easy DIY project. No problems for 30,000 miles now. Good luck.
Old 04-24-2004, 07:32 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
do you have a mechanical gauge on it or a factory electric? if it is mechanical, sounds like the pickup got yanked off or you have low oil level. I have seen motor where the pump was still low enough where it sucked oil but the second you make the flow flow to a side of the pan it would suck air and you would lose pressure.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
95 Ram 1500 Heater problems ocpaul Ram Pickup | Ram SRT10 3 11-13-2009 04:24 PM
1996 dodge ram 1500 oil consumption mr fix it Ram Pickup | Ram SRT10 13 04-05-2009 11:55 PM
92 Dodge Ram 1500 oil pump stilts07 Ram Pickup | Ram SRT10 1 02-24-2008 12:13 PM
Ram 1500 brake problem crocks80th Ram Pickup | Ram SRT10 4 05-14-2004 11:34 PM
Ram 1500 oil gauge ljeter63 Ram Pickup | Ram SRT10 6 01-09-2004 02:02 PM
