Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-24-2003, 09:45 AM
ljeter63 ljeter63 is offline
Ram 1500 oil gauge
2001 Ram 1500 w/ 5.2 litre engine, 53k miles. Oil pressure gauge basically just died - straight to 0 while driving down highway. Immediately shut down and checked oil level - OK. At start gauge goes to normal 60 psi +/-. W/in three minutes dies to 0. No fade, just dies & check gauges light & bell goes comes on. Temp. gauge shows no rise, RPM stays steady. Ideas?
Old 12-25-2003, 05:44 PM
koozie koozie is offline
oil pressure
I have the saame problem going for about a week now--think its the by pass valve in the oil system--only problem I'm not sure where the valve is--either on the pump or above the filter--will call a dealer tomorrow--I drained oil and put new filter on and refilled with a bottle of lucal oil treatment and 20-50 oil till I can get valve checked--holds excellent pressure now--just don't know for how long.
Old 12-27-2003, 11:16 AM
Re: Ram 1500 oil gauge
I'm doing the exact same now. Hope it hoolds pressure. Let me know.
Old 01-06-2004, 06:39 PM
Pulled the oil pan and found pick up screen about 70 % clogged--replaced pump and cleaned screen--still may have had a bad by-pass valve in the old pump--everything running good now
Old 01-07-2004, 07:55 AM
Since I've changed the oil & filter I haven't had a recurrence, but I'm thinking you may have the best approach. Good luck.
Old 01-09-2004, 01:59 PM
fahrfrumwurkin55 fahrfrumwurkin55 is offline
oil pressure sending unit..
mine did it and the sending unit fixed it..
also check for a bad ground on the sending unit circuit.
Old 01-09-2004, 02:02 PM
Thanks for the info.
2003 Dodge Ram 1500 (Crazy Gauges and Test light) ellis479 Ram Pickup | Ram SRT10 2 12-29-2009 11:11 PM
95 Ram 1500 Heater problems ocpaul Ram Pickup | Ram SRT10 3 11-13-2009 04:24 PM
1996 dodge ram 1500 oil consumption mr fix it Ram Pickup | Ram SRT10 13 04-05-2009 11:55 PM
92 Dodge Ram 1500 oil pump stilts07 Ram Pickup | Ram SRT10 1 02-24-2008 12:13 PM
99 Ram 1500 Oil Problem Powder Ram Pickup | Ram SRT10 3 04-24-2004 07:32 PM
