Old 04-13-2004, 10:00 PM
exmil77 exmil77 is offline
Headlamp switch? Bare wire? HELP!
I have an 88 cherokee limited, 4.0. Im getting ready to license it, and have run n2 a problem. I have no tail lights, or dash lights. I replace the fuse for them, and turn the key on, not over, and they work just fine. I start the Jeep, and the fuse blows. What is causing this? Bare wire? If so, where on earth would I begin to look for this? ANY help would greatly be appreciated! Thanks...
Old 04-14-2004, 12:30 PM
Dale Aeppli Dale Aeppli is offline
Re: Headlamp switch? Bare wire? HELP!
HI , IT SOUNDS LIKE YOU HAVE A SHORT ON THE START & RUN SIDE OF YOUR IGNITION SWITCH. DALE [email protected]
Old 05-07-2004, 09:18 AM
BikerTrash BikerTrash is offline
check your switch, mine did the same thing and the switch was bad
Old 08-13-2004, 03:43 AM
irishsetter48 irishsetter48 is offline
how did you solve the problem?
EXMIL77,
What did you finally do to solve the electrical problem? I have the same problem and I replaced the switch and it still blows the 10 amp fuse. Thanks for your help.
transmission wiring help please danielgast46 F Series 0 02-28-2009 09:33 AM
'92 Cherokee headlamp switch malfunctioning fitzy78 Cherokee 3 10-23-2005 08:19 PM
Ignition switch broken wiring help?? Thoughts? a91civic '88 - '91 Civic | CRX | Wagon | Shuttlee 7 10-05-2004 09:37 PM
headlamp switch RB25240kouki RX-7 7 06-23-2004 08:25 PM
toggle switch, and wiring help on location mandkal Corolla/Matrix/Voltz 1 10-28-2003 08:05 AM
