Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 04-13-2004, 12:49 PM
bluehorse1968 bluehorse1968 is offline
Dtc - P1296
My wife drives a 2002 VW Beetle 2.0 Auto Trans. The check engine light is on and when I run the OBD II Auto Scanner on it I get the P1296 code. Can someone please tell me what this code means?
Old 04-16-2004, 03:02 PM
boschmann boschmann is offline
Re: Dtc - P1296
P1296 indicates a cooling system malfunction. Is the vehicle warming up properly & reaching operating temp in a normal manner. Usually it is something like a stuck open thermostat that makes it take too long for the engine to warm up. It could also be a problem with the coolant temp sensor.
Old 04-18-2004, 08:59 AM
Re: Re: Dtc - P1296
Thanks for the info. It appears that it might be the thermostat sticking open. This VW has a cold temp light and it appears to be warming up abnormally. I will monitor the warm up period closer and will update this forum once I repair the problem. Thanks again !!!
I monitored the cold temp light for approximately 1 week. At Idle, with a cold engine, it averaged approximately 5 minutes each time before the light would go off. I decided to change the coolant temp sensor and so for so good. It had the black ECT, I replaced it with the green. Thanks Again !!!
Passat OBD code P1296 Help! bos_passat Passat 2 12-28-2006 03:49 PM
Engine Code P1296 Demolician '94 - '01 2 06-02-2005 11:28 AM
02 Passat error code P1296 FastM '97+ 3 10-08-2004 09:53 PM
P1296 Injector Multiple Faults - Bank 2 ebadboy Off-Topic 1 08-04-2004 10:14 AM
P1296 Injector Multiple Faults - Bank 2 ebadboy Eclipse 2000+ 1 08-03-2004 11:42 PM
