Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 04-13-2004, 12:19 PM
kali kali is offline
Question TDi Z1 engine direction indicator stops flashing when brake pedal is depressed
When driving and when indicating a turn the flasher works but as soon as there is any pressure on the brake pedal the direction indicator stops flashing.
Does anyone know what may be causing this problem?
More recently, driving along motorway (freeway) and glow plug indicator starts to blick (on/off). A slight depression on the brake stops the glow plug indicate from blicking on/off. But sometime later it starts again.
There is no obvoius fault with the function of the vehicle.
key words: direction indicator stops flashing blicking depress brake pedal Z1, TDi
Old 04-13-2004, 05:03 PM
boschmann boschmann is offline
Re: TDi Z1 engine direction indicator stops flashing when brake pedal is depressed
If this is an A3 body it is probably a bad connection at the taillight bulb holder. There is an eight pin in-line connector that commonly corrodes (usually the ground wire connector fails). A blinking glow plug indicator usually means water in the fuel. Check & drain the water seperator.
Brake pedal does not return bhw33191 Caprice 8 08-29-2009 10:06 PM
1993 Lexus GS300 Engine Quits When Brake Pedal Pressed iowafan GS300/GS400/GS430/Aristo 1 07-08-2006 12:30 AM
hazards stop flashing when I apply my brakes on my chevy pick-up Felix Custom Silverado 4 08-23-2005 01:29 PM
2000 Explorer revs when clutch pedal depressed MattBG20t Explorer | Explorer Sport Trac 0 03-17-2004 07:34 PM
