Old 08-22-2005, 06:04 PM
Felix Custom Felix Custom is offline
hazards stop flashing when I apply my brakes on my chevy pick-up
When I press the brakes they work, when I try the signal lights they work, when I try the hazards they work, but when I press the brakes and use the turn signal all my lights to haywire and with the headlights on the taillights dim when using signal or brakes. When I put hazard lights on they flash but as soon as I press the brake they stop flashing, they just stay lit. I've checked all the wiring, and there is no trailer wiring, I've checked the fuses and bulbs, what's left. Could it be the turn signal switch in my steering column? Oh! and I did check the chasis ground, I removed it and sanded it, still the same problem.
Old 08-22-2005, 06:55 PM
mrcrabbiepattie mrcrabbiepattie is offline
how about you flasher relay runs through your brake wiring?
Old 08-22-2005, 07:13 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: hazards stop flashing when I apply my brakes on my chevy pick-up
The hazard flasher will be overridden by the brake lights, causing them to stop flashing. IF IT IS A 88-98, but you didn't say.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 08-22-2005, 08:21 PM
nineball481's Avatar
nineball481 nineball481 is offline
Any vehicle that does not have the amber turnsignal in the tail light section will do as you described. Car makers feel it is more important to say that you are stopping/stopped rather than tell them you might be moving slowly.
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 08-23-2005, 01:29 PM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
right. normal operation for the flashers to stop when pressing brake pedal. using the same filiments for the brake lamps. if you had amber hazards, it would be a different story.
