Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-13-2004, 04:55 AM
tds715 tds715 is offline
Send a message via AIM to tds715
having a starting problem
i have a 92 gsr. the starter doesnt turn over at all. but i took it out and had it tested. all wires seem like there intact. is there a type of fuse i coudl have blown or something where the starter may not be turning on?
Old 04-13-2004, 10:50 AM
integrasedan integrasedan is offline
could be a fuse but i dunno where it is
check the ground wires for good condition and tightness
check battery for proper charge.
Old 04-13-2004, 11:18 AM
IntegraB16 IntegraB16 is offline
Re: having a starting problem
Fuses huh.... I know of only two places where fuses are. inside the car on the drivers side by the on the left kinda by the cluth pedal. And under the hood on the passenger side right by the strut bolts. They are in a plastic box. Check all thoes. Then if that still don't work check the wire that connects to the battery. I have had that break apart on me before. There is also a plug that connects to the starter from the wiring harness. I guess if all thoes don't do it you might have to start following wires and seeing if there are any breaks. Thats all i can think of.
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
Do you have Starting Problems???? phixion009 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-10-2004 08:10 PM
Having starting problems shadow_matrix0101 323/Protegé/Familia/Etude/Allegro 2 08-21-2004 07:09 PM
still have starting problems! myoung7 Blazer 9 03-06-2004 11:53 PM
