Old 04-13-2004, 12:12 AM
Light Show Light Show is offline
IDLE problem
my car while in neutral or park idles around 2000, while in a gear (automatic) it stays at 1 or 1.5, but you can feel that its idleing high. any suggestions?
Old 04-13-2004, 07:23 AM
Jeremy-WI Jeremy-WI is offline
Re: IDLE problem
might need a coolant temp sensor, the computer may think the vehicle hasn't warmed up
Old 04-13-2004, 10:41 AM
that would make sense/my temp gauge as been jumping around alot. not slowly, but quickly shacking back and forth. Thermostat has been change, same with the water pump. so ill try the sensor, anyone know where its at on a 94 lumina z34?
Old 04-13-2004, 11:31 AM
Re: IDLE problem
They are usually close to the thermostat in the intake manifold
Old 04-13-2004, 12:09 PM
Talking
I changed it out/and its idling fine. I have to go to work, but im going to take it for a drive later on tonight.. Thanks for the info.
Old 04-15-2004, 12:18 AM
ok i took it for a ride today and my fans are not kicking on and the idle problem is back. Any other ideas?
Old 04-16-2004, 12:40 PM
Lumina95 Lumina95 is offline
Re: IDLE problem
Check the Idle Air Valve
Old 04-18-2004, 07:01 AM
Re: IDLE problem
Start looking at the wiring for the temp sensor, maybe even with the car running at high idle start wiggling them around to see if idle drops/fans run
Old 04-22-2004, 03:33 PM
toivo toivo is offline
Re: IDLE problem
ther are usually 2 temp sensors, make sure you got the right one. the fans are run by a relay that is powered by the temp sensor.
Old 04-29-2004, 11:12 AM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
Re: IDLE problem
i have same problem in my 98/3.1 occurs randomly, nothing in the throttle linkage binding, as the plate is firmly touching the idle screw. replaced teh pcv off the bat, still happens. I keep thinking vacuum b/c all the experience in the past with carburated engines that was sometimes teh fault - no idea if that carries on to computerized fuel injection.
AT ONE TIME, the hush panel was keeping the accelerator pedal from moving all the way back, check that.
my temp gauge is steady. occurs cold and hot. sometimes tapping the accelerator helps. sometimes it happens for a couple minutes, sometimes for 50+ miles.
Old 04-29-2004, 09:35 PM
Re: IDLE problem
oh yeah, and my current problem with my intake gaskets that are leaking (common problem) - an intake leak can cause a high idle... check your intake all around find any trace of brown sludge near your gaskets, or any trace of antifreeze leaking
I have the high idle problem AND the leaky intake gaskets, you might, too.
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
1987 Grand Marquis 5.0L FAST IDLE problem Johnobub Grand Marquis 3 10-09-2009 08:10 AM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
