Old 04-12-2004, 11:23 PM
swamprat swamprat is offline
wont start when hot
I have searched and searched locally and on the Internet for 3 days now trying to find out why my car wont start (89 Camaro 2.8L Multiport) when it is hot (or at least ran for awhile) seems no one has an answer. Seems also that I am not the only one with this poblem so I am posting what I did find for anyone else having the same problem.
These are all the answers I have found to the question "wont start when engine is hot"
USE AS NEEDED i.e. if you know one of these is NOT your problem then move onto the next. Good Luck.
[copy from autozone.com]
1 BATTERY Damaged or faulty battery and/or connections.
2 COIL - IGNITION Damaged or faulty ignition coil or ignition coil circuit.
3 FUEL FILTER Clogged or dirty fuel filter
4 FUEL INJECTOR PRESSURE REGULATOR Faulty fuel injector pressure regulator or circuit.
5 FUEL PUMP Improperly functioning fuel pump or circuits.
6 WIRESET Damaged, worn, or deteriorating spark plug or coil wire(s).
7 CONTROL MODULE Faulty ignition control module or circuit.
8 SOLENOID SWITCH Damaged or faulty solenoid switch or solenoid switch circuit.
9 STARTER Damaged, worn, defective, or faulty starter or starter related circuit.
10 NEUTRAL SAFETY SWITCH Damaged or faulty neutral safety swittch or circuit.
11 FUSE Corroded, burned, or shorted fuse may be interupting power source.
13 BATTERY CABLE Corroded, broken or poorly connected battery cable.
15 DISTRIBUTOR CAP Loose or cracked distributor cap
16 DISTRIBUTOR CAP AND ROTOR KIT Loose, cracked, or worn distributor cap and ignition rotor.
17 FUEL SYSTEM PRESSURE Incorrect fuel pressure being delivered to carburetor or fuel injection system.
18 FUEL INJECTOR Plugged, dirty or poorly connected fuel injector.
19 IGNITION SWITCH Worn, damaged or faulty ignition switch or circuit.
20 SPARK PLUG Fouled, damaged or broken spark plug(s).
21 BELT Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s).
22 TIMING BELT Slipped or broken timing belt.
23 TIMING SET Slipped timing chain or worn timing gear(s).
24 FUEL TANK Contaminated fuel from rusted or deteriorated fuel tank.
25 TIMING SPECIFICATION Incorrectly adjusted engine timing.
Old 04-12-2004, 11:25 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: wont start when hot
thats a big list...
Old 04-13-2004, 02:39 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
tis a big list! so after all that did you find the problem with your car swamprat?
Old 10-12-2004, 03:14 AM
Unhappy Re: Re: wont start when hot
YUP! faulty fuel pump, which, naturally is in the tank and I have to drop the rear end to remove it
Old 10-12-2004, 11:38 AM
took ya a little while to answer that one...
*Better power-to-weight ratio than a C6 corvette*
Old 10-12-2004, 08:24 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
He'll get back to on why it took so long in June.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-13-2004, 01:14 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
lol
Wont start when hot, Starts and runs cold fine jjsfollys F-Body Problem Diagnosis 12 07-29-2015 07:13 PM
94 Blazer wont start when hot timh059 C/K 2 11-05-2004 03:07 PM
delta 88 wont start when hot a7x278 Eighty Eight 5 07-23-2004 12:08 PM
wont start when hot rosshatch89 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 06-13-2004 11:07 PM
1994 camaro z28 wont start when hot tyranny681 Camaro Discussions 3 03-24-2004 07:21 PM
