| Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models |
delta 88 wont start when hot
put new plugs in it and it will start if its sat for about 2 hours after running but wont start if turn it off to run into the store. ive heard that its the celonoid, timing belt, and coil pack but dont want to put too much money into it being how theres 210,000+ miles on the motor
Re: delta 88 wont start when hot
When you say doesn't start do you mean it does not crank over or cranks but does not start?
it cranks but wont start
try hooking up a tech 2 to the car. I had just checked a bonneville with the 3.8 v6 in it. Same problems, starts fine cold, stalls when gets hot and doesn't start at all when hot.
The Tech 2 pointed toward the camshaft position sensor, Im not sure if it is the problem yet, I will let ya know.
___________ ...... ![]() /|____________|\ [|___\==A==/___|] [...-------------...] ||||________|||| |
There was recently a safety recall on some pressure regulators for Olds,pull the vacuum line from the pressure regulator and check for fuel in the line (after the engine sits for a few minutes when hot.) This may not be the answer but worth a try.
i plan to hook it up to the comp i just have to bring it to the shop
