Old 04-12-2004, 10:27 PM
Dr Juice Dr Juice is offline
Send a message via AIM to Dr Juice Send a message via MSN to Dr Juice
Need Torque specs
I need the torque specs and squence of the rocker arm assemebly of a d15b7 motor, SOHC non Vtec
Old 04-13-2004, 04:48 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Need Torque specs
The 8mm main bolts are 16lb-ft
the 6mm ends are 9lb-ft
11--7--3--1--5--9--13
12--8--4--2--6--10--14
Old 04-14-2004, 04:29 PM
only 1 prob there are only 12 bolts that go accross
Old 04-14-2004, 04:35 PM
theres 16, because you have two on each end that are a different size.
Old 04-29-2004, 05:45 AM
that the looseining sequence or tightening
Old 04-29-2004, 06:51 AM
Tightening
Need torque specs real quick russ_951 Ram Pickup | Ram SRT10 5 02-19-2006 08:29 PM
Help! Need Torque Specs Soon Schmidt Neon | Plymouth Neon 4 06-04-2005 11:43 AM
Replacing 96 5S-FE engine, need torque specs call831 Camry/Camry Hybrid/Vista 1 05-30-2005 05:54 PM
need torque specs bad! tonylittell 626/Capella/Capella Wagon 1 12-19-2004 06:32 PM
need torque specs from head up. 99 integra 240mph Integra 0 07-02-2004 01:16 PM
