Old 04-12-2004, 10:14 PM
mike123 mike123 is offline
keep losing
so ive been racing my friend that has a 91 3000 gt or a 96 or something , when i take off im usually ahead of him till like 3rd gear , when i shift into 3rd and floor it , i slow down like theres no combustion or something , but if i go through my gears slow like normal driving there is no problem , just wanted your insight on it
Old 04-12-2004, 10:50 PM
MaxCamaroZ28's Avatar
MaxCamaroZ28 MaxCamaroZ28 is offline
What kind of Car is it, engine? Mods? any problems that you know of in the past?
Old 04-12-2004, 11:03 PM
Re: keep losing
this car is kinda new to me had it for like a month or two? umm its a 305 carb with a 5 speed , this problem isnt new but im still not sure what is causing it , i need to check my timing i just havnt cause its in the worse postion possible
Old 04-13-2004, 12:43 AM
Probably have to tell a whole lot more info then that, year and all... also have you tried setting the idle, checking plgs and wires, etc. There's a lot of things that could possibly be wrong with it, the more info you put on the forum the better someone can narrow it down for you.
Old 04-13-2004, 02:33 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: keep losing
need more info! sounds like its just premature shifting to me.. 3rd gen's were always bad after 2nd gear..
Are you sure your slowing down? Maybe it just seems that way when your buddy's turbos spool up and he blows by you
Old 04-13-2004, 09:07 AM
MarxZ/28 MarxZ/28 is offline
Re: Re: keep losing
either premature shifting or your transmission is on its last limb
Old 04-13-2004, 02:39 PM
DaMoNe6969's Avatar
Re: keep losing
Well from the way he's talkin, he's got a 5speed..
Maro's were always kinda slow after 2nd gear until the T-56 came out.. That plus he could be shifting a little too early in the power band
Old 04-13-2004, 05:10 PM
Re: Re: keep losing
yea they were kinda slow after 2nd gear...but hes sayin its beyond slow, like zero acceleration (no combustion (as if you were to roll in nuetral)). the camaros never did that
there is a problem
Old 04-13-2004, 05:26 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: keep losing
Well when I got my first third gen with a 5 speed if I was racing and shifted into third before 4500rpm then it seemed like it was dead, but if you shift right at or just after 4500 then you'll chirp the tires and keep going. If that doesn't work then you need to check your timing and make sure your right on point. Also, you might want to invest in a 50000v coil, that'll help too. New plugs and wires are a plus and a new air filter. If that doesn't fix it then it's probably a compression problem. Since the engine doens't have to work as hard in the lower gears then you might not notice it as much as the higher gears. Get a compression checker and check all the cylinders.
Old 04-14-2004, 12:45 AM
DaMoNe6969's Avatar
Re: keep losing
yeah... what he said
Old 04-14-2004, 12:56 AM
Re: keep losing
yea i got a compresion checker at the house right now ive just been lazy , i hope to get my 350 block this weekend i put in a bunch of hours like today i worked a 11hour shift , but yea ive pulled a couple plugs they wernt that bad, wires arnt that bad i have newer ones just been lazy
havnt checked the timing cause its right behind the water pump and its a bitch
RPO codes
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VG8 : VEHICLE, BUYER NOTICE LABEL
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
Unable to locate code YAY in our database!
YF5 : CERTIFICATION, EMISSION, CALIFORNIA
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
Unable to locate code 1ST in our database!
49A : STRIPE COLOR ACCENT LT ANTELOPE (91)
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
Unable to locate code 621 in our database!
Unable to locate code 629 in our database!
7ZW : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
81U : PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01 : WINDOW, TINTED, ALL SHADED, W/S
B3W : Advanced Price Sheet Processing Option
B94 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR I
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D08 : PAINT, HIGH GLOSS FINISH
D34 : MIRROR, VISOR VANITY
D35 : MIRROR, OUTSIDE REAR VIEW
Unable to locate code D7G in our database!
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
Unable to locate code E57 in our database!
Unable to locate code E7Z in our database!
F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
GU5 : AXLE REAR, 3.23 RATIO
J50 : BRAKE SYSTEM, POWER
K60 : GENERATOR, 100 AMP
LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
NB2 : EMISSION SYSTEM , CALIFORNIA , TIER O
Unable to locate code BP5 in our database!
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
PB4 : LOCK CONTROL, WHEEL
P20 : HUBCAPS, WHEEL, STYLED
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
T93 : LAMP, TAIL & STOP, SPECIAL
UL6 : RADIO, AM, CLOCK, MTR
UP7 : RADIO PROVISIONS, FOR MONO INSTRUMENTATION
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
Old 04-15-2004, 07:36 PM
BAMiller BAMiller is offline
I would check your fuel filter first, it sounds like it could be leaning out @ high RPM. If thats OK check your fuel pump pressure and volume. Q-jets are great carbs but they have very small fuel bowls and if your pump can't keep up the fuel bowl can go very low under high RPM.
Old 04-15-2004, 07:54 PM
Re: keep losing
Check the vacume advance on your carb also, if it's sticky then that will cause the same problem, carb cleaner will usualy fix it, or just get a new manifold and carb.
Old 04-15-2004, 08:57 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
check the accelorator pump
Old 04-15-2004, 09:30 PM
Re: keep losing
will im replacing the fuel pump tomorrow cause i checked the vacum on it but not sure what teh regual psi should be
Keep losing :( FastFreakinCorolla Corolla/Matrix/Voltz 17 08-03-2006 02:35 PM
bmw 328i keeps losing coolant logikltd 3 Series 2 09-04-2004 02:15 PM
Tires keep losing air pressure meboggan Town Car 2 07-14-2004 05:19 AM
98 Escort ZX2 keeps losing serp belt? twlunn Escort 4 02-10-2004 03:53 PM
