Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 09-04-2004, 10:51 AM
logikltd logikltd is offline
bmw 328i keeps losing coolant
i have a bmw 328i, about 7 years old and approx 200,000 miles on the clock, have noticed that the coolant keeps droping in radiator, right down to bottom, and on a short journey, it can fill up again when i have drove for 30 mins, but most of time it just looses coolant over engine. it seems that it is leaking out of the engine somewhere under the injectors . but is it very hard to see. i pulled out the out the oil dip stip with engine running and there is a very noisy gurgling sound that is not normal. there does not seem to be oil in the radiator or water in the oil could this be a head gasket problem?
Old 09-04-2004, 12:08 PM
cpowell cpowell is offline
Send a message via AIM to cpowell Send a message via MSN to cpowell
Re: bmw 328i keeps losing coolant
sounds line a head gaskit to me too
Old 09-04-2004, 02:15 PM
found what seems to be the problem, a small hole/split in a hose that goes into engine/cylinder under the inlet manifold. awkward to get to had to take the injectors out think i can just cut a bit of the hose and reconnect it. thanks for your help. gona have a drive see if it works shortly
