Old 04-12-2004, 02:12 PM
stubbs_GS-T stubbs_GS-T is offline
Question What next?
I have just begun to upgrade my 95 gst, here is what I have:
greddy type-S BOV
greddy upper/lower intercooler piping
high flow cat/ straight pipe
injen intake...
Should I upgrade my turbo? If so what are my option, and which is the best bang for my buck?
What exactly does a boost controller do?
Thanks for any info
stubbs
Old 04-12-2004, 02:28 PM
95GSTRaCeR 95GSTRaCeR is offline
Re: What next?
You may want to look into upgrading your fuel system, ie. injectors, fuel pump. If you do some fuel mods then a turbo I hear that would be good is the 16g. Running DSMlink would be a great upgrade also, because along with everything else it does it lets you tune your a/f ratio. Tuning your a/f ratio in some way is a must for running an upgraded fuel system and a bigger turbo. Another ways to tune is a SAFC, but then you would also want to get a datalogger, the best way to go though would be DSMlink because it incorporates a datalogger. This is all from stuff that I have read from other posts here, if you haven't already, do a search and you will get loads more stuff on upgrading paths.
Old 04-12-2004, 02:29 PM
RattlesnakeGST RattlesnakeGST is offline
Youll probably want to get upgrade the clutch first so your car will be able to handle the addition power youd get from a bigger turbo... ACT 2100 or 2600 etc..
Old 04-12-2004, 09:32 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: What next?
do you have a real boost gauge because the factory gauge isnt an actual gauge it's just the ecu estimate from a couple other sensors and it loses accuracy fast when you start modding
buy a real boost gauge before you run higher then stock boost!
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-12-2004, 09:56 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: What next?
ya get a boost gauge next before anything else. a boost controller basicly controls when to open the wastegate in order to control boost pressures. depending on what you have to spend you can get a manual one or an electronic one. as far as the best bang for buck on a turbo, look into getting a used 14b [stock on early 1st gens]. usually you can get one for under 100 bucks and an install kit for cheap. also a fuel pump will solve raising boost pressures for now. a 190lph will be fine.
Old 04-12-2004, 10:07 PM
Raz_Kaz Raz_Kaz is offline
Re: What next?
greddy type-S BOV
injen intake...
Thanks for any info
stubbs
Dude....http://dsmtuners.com/tuning-guide/2gturbo/ ....hope it helps ya
drive safe
Old 04-13-2004, 12:31 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: What next?
What does a boost controller do? http://racingknowledge.org/topic.asp?TOPIC_ID=117
Upgrade paths:
http://www.jumptronix.com/2g_go_faster/index.htm
http://www.roadraceengineering.com/2gupgradepath.htm
http://www.dsmtuners.com/tuning-guid...tage1power.php
Have fun reading. Check out the site list also, there are so many answers here, DSMtuners, RKO, etc... it's not even funny.
tranny rebuilt...what next in future? mgcatthew Accord/TSX/Accord Hybrid 5 04-24-2002 03:50 PM
New G20, but whats next- help? taurus252 General 4 02-26-2002 01:41 PM
b18a whats next hb7 '71-'87 Civic | CRX 4 02-03-2002 07:46 AM
What next for my suspension? hondacsi Tires and Wheels 10 01-22-2002 05:08 PM
Bought my first G20 today!!!....what next?? northwestrally General 7 05-03-2001 12:31 AM
