Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 04-12-2004, 12:40 PM
da_bad_man da_bad_man is offline
Converting from AFM's to Pressure Sensors
Hi Eyeryone
This may seem like a silly question but i'll ask it all the same!
I've got the spec and some pics of an R32 GTR running a T51 WITHOUT Air flow meter/s but WITH an Apexi power FC.
I asked around when i first installed my Power FC as to wether it is possible to remove the AFM's and convert but i was told only if i upgraded to a link or Motec.
Please can someone explain if it is in fact possible to do this and if so how?
Thanks everyone
PS If anyone wants to know why i want to do this.......i'm installing a pair of 2835's and i dont really want to have to shell out for bigger AFM's.
Old 04-13-2004, 12:23 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Yes, its called a D-jetro. I just bought a one, its being shipped from the states. Actually, the guy has 2 units, one of them being a D-Jetro, and the other being a L-jetro. He is rethinking the D-Jetro deal, and is seeing if I will take the D-Jetro. Either way, both kits will work for me.
He did tell me that the D-Jetro is a pain to set up, and you are limited on the boost level you can run. I am not sure if will work for your application because of the turbos you have.
If you want more info, I can post it on the D-Jetro.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-13-2004, 12:30 AM
SkylineUSA's Avatar
Sorry, if you have seen a T51 run with a D-Jetro, it probably will work for your application, but it is a pain to set up.
How much have you been quoted for the 300Z air sensors? I might be able to sell you some. My power levels, I probaly will not need them, and I am getting some in the L-Jetro deal.
Old 04-13-2004, 12:34 AM
R33's Avatar
R33 R33 is offline
Send a message via Yahoo to R33
HKS has what it calls Vein Pressure Sensor to replace the AFM. But that's old story. Now, if you use the HKS F Con V Pro, it is built in in the ECU.
Hey, what are you doing in the fast lane?
Old 04-13-2004, 01:13 AM
SkylineUSA's Avatar
As far as I know, you cannot tune a RB26 with the HKS F Con in the states, but you can with a PowerFC. That is why everyone runs the PowerFC in the states.
Old 04-13-2004, 03:37 AM
GTES-t's Avatar
GTES-t GTES-t is offline
There are also other options. If you use a piggyback ECU system, Greddy's eManage has an optional pressure sensor and harness so you can run a MAP sensor instead of the AFM.
1990 Skyline GTE/S-t 4 Door Updated 6 Mar
Swapped out RB20E with RB20DET
Trans converted from Auto to 5-Speed...
Now with SR20DET 5-Speed
Installed Type M 5-lugs and brakes, R32 GTR rims and 2-Dr rear end (Tail lights & bumper)
1994 Isuzu AMU
US Spec Amigo with JDM Isuzu MU (Mysterious Utility, as it's called in Japan) nurf bars and hatchback style hardtop.
Old 04-13-2004, 12:48 PM
Thanks everyone for clearing that up for me! I was getting a little confused with what was going on!
How would i know if i have the D-jetro version of the Power FC? I've only just bought it and wouldnt like to have to get rid!
I did have the greddy but got rid of it for the Power FC as the majority vote was for it.
Thanks for the offer SkylineUSA but i already bought some a while ago just in case ..... wish i knew you then!! :-(
I'm sure i saw a pressure sensor setting in the AFM type selection on the menu of the hand controller?
Thanks
Old 04-13-2004, 12:57 PM
SkylineUSA's Avatar
You should have 2 Apexi Map Sensors for D-Jetro? Did it come with it?
Where did you get that unit from?
Old 04-13-2004, 01:01 PM
I bought it from a very ropey (dodgy) dealer here in the uk.
No it didnt come with any extra sensors. i take it that its not as simple as just adding two map sensors? do you know of anyone thats got a D jetro?
Thanks again for your help.
Old 04-13-2004, 01:07 PM
SkylineUSA's Avatar
I know of only one guy here in the UK that has one. Where are you located? I live just north of Swindon.
I will see if I can find you his e-mail address.
Old 04-13-2004, 01:12 PM
SkylineUSA's Avatar
I am still waiting for my unit, so I have not played with it yet.
This guy is the person you need to talk to [email protected]
If you cannot get a response to your questions, let me know.
Old 04-13-2004, 01:18 PM
You and everyone else on here have been absolutely brilliant!
Thank you very very much.
1997 Sebring Convert. dashboard temp/directional sensor. mark44004 Sebring | Sebring Coupe | Convertible 0 06-18-2009 03:04 PM
Oil Pressure Sensor location? 95Orvis Grand Cherokee | Grand Cherokee SRT8 5 09-16-2004 02:35 AM
oil pressure sensor housing leak? 4bz Grand Cherokee | Grand Cherokee SRT8 2 01-04-2004 05:43 PM
AC Pressure Sensor Lockhorn Blazer 2 07-30-2003 09:35 PM
