Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-05-2004, 06:56 PM
95Orvis 95Orvis is offline
Question Oil Pressure Sensor location?
My Oil Pressure Guage is having siezures and bounces from one end to the other. I have the Haynes book and have looked where they say the location of the sensor is, but I can't find it. I looked all around the oil pan where it said it should be, but no luck. Any thoughts where they are hiding it? Should I even really care? Will it cause downstream problems?
95 Grand Cherokee Limited (Orvis Edition), 5.2L
Thanks,
Old 02-08-2004, 10:24 AM
cbr92901 cbr92901 is offline
Same thing is happening with mine - 95 Orvis - it's been doing it for a couple years with apparently no adverse effects.
Old 02-16-2004, 05:31 PM
batres batres is offline
Re: Oil Pressure Sensor location?
It is located at the back of the engine behind the intake manifold next to the distributor cap.
Old 02-16-2004, 06:45 PM
Thank You, Thank you, Thank You.
I'll check it out.
Old 03-16-2004, 03:55 PM
jeep96josh jeep96josh is offline
I am having the same problem also.
Is it easy to replace on my own?
Does it require me to change the oil filter?
Old 09-16-2004, 02:35 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
No you don't have to change the filter. it is easier to c if u take the Sparks Plug wires off the Distributor cap, it is on the passenger side of the cap. right next to the EGR valve.
Oil Pressure Sensor Location Diag LeSabre 6 10-20-2008 09:24 AM
99 Pathfinder oil pressure sensor location cableguy4k Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 08-05-2006 02:41 PM
Oil pressure sensor location danpletch Silhouette 2 06-09-2006 04:56 PM
92 3.1 oil pressure sensor location bridgmon Cavalier 0 08-09-2004 09:37 AM
