Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 04-11-2004, 09:47 PM
R33's Avatar
R33 R33 is offline
Send a message via Yahoo to R33
NoS
Guys, another question. Let's just say I want tp put in a 75 or 100 shot. I wud have to retard the timing by about 2-4 degrees.
My plan is that I am only gonna use this on the track, coming out of slow corners and also at those turns leading to long straights.
The problem is this. I am now using the F con and it does not support NoS application. That means if I retard the timing, it wud stay even if the NoS switch is off! Meaning, I wud lose power if I not using NoS. I don't want to change ECU. Is there an electronic wonder which could retard the timing (after being programmed of course) when the laughing gas is being sprayed and wud revert the timing to my non-NoS timing when NoS is not used?
I know Haltech n Motec ecus cud automatically do this. Is there an outboard thingy which cud do the same?
Hey, what are you doing in the fast lane?
Old 04-12-2004, 06:32 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: NoS
There are piggy back ECUs that will do that with your stock ECU, but I dont know if they would work with the F con
Old 04-13-2004, 12:42 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
If you run a 50shot, you should not need to run a colder plug, or reduce your timing. A 50 shot on a turboed car will net you around 75-100hp anyways. It will have to be a direct port, or those new injector sleeves that combine the N2O with your injector port.
Which turbo application are we talking, the new 2530s?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-13-2004, 12:45 AM
SkylineUSA's Avatar
I forgot to add, with a 100 shot your going to have to run a big ass bottle, or 2 10lbs to last a while. Which means more weight.
Old 04-13-2004, 06:22 PM
R33's Avatar
R33 R33 is offline
Thanks Sky. Am actually thinking of installing it together with the 2530s later in the year. But it's just a thought. The immediate thing to do now is to install the 2530s and do up my g/box. I am now looking at various ratio offered by OS Giken. The plan is to probably find a short ratio for 2nd/3rd and 4th while maintaining the stock ratio for 1st and 5th. With those things done, the car will be retuned. The NoS may or may not come after that.
Old 04-18-2004, 03:48 AM
raysoh8's Avatar
raysoh8 raysoh8 is offline
Re: NoS
(i dont understand a word you 2 are saying)
isnt NoS illegal in malaysia?
Old 04-18-2004, 03:16 PM
SkylineUSA's Avatar
Re: Re: NoS
We said it in plain english
Old 04-18-2004, 06:40 PM
R33's Avatar
R33 R33 is offline
Re: Re: Re: NoS
Nope Raysoh. There is no law which prevents the usage of NoS on or of the road. Racing regulations however restrict its usage, but not the law.
Old 04-18-2004, 11:53 PM
SkylineUSA's Avatar
Remember you can never use NoS, NoS is a company. You can use N2O
Old 04-19-2004, 01:43 AM
R33's Avatar
R33 R33 is offline
Old 05-15-2004, 01:12 PM
SpeedFreek9000 SpeedFreek9000 is offline
Banned
Re: NoS
i wanna put A nitrous system on a 1998 R34, but have no clu where to start? can anyone help me out?
Old 05-15-2004, 03:34 PM
SkylineUSA's Avatar
Re: Re: NoS
You might want to start by getting a car
See this is an easy one to pick out
Old 05-18-2004, 05:52 AM
raysoh8's Avatar
Re: NoS
how do you point them out?
Old 07-18-2004, 06:00 AM
2rismo 2rismo is offline
Send a message via ICQ to 2rismo
Re: NoS
Just to elaborate on one of the points made here for a sec. It is VERY important that you have a direct port setup on your GTR. The front facing plenum has far from even distribution of the inlet charge and can cause engine-melting problems when nitrous is introduced from a single point.
On my gts-t this is much less of a problem and i run a 75hp wet shot introduced immediately before the throttle body.
I reckon run more boost on a better prepared motor rather than lug a big-ass bottle of n2o around the track but that's just the whining of a straight line racer
Can I also suggest you look into the newer HKS GT-SS turbines which offer similar response to 2530's but similair power to 2540's. Awesome circuit turbines.
Adrian
NOS NOS bloody NOS!! Pennzoil GT-R Street Racing 4 07-21-2002 10:11 PM
to nos or not to nos scaterdilusions '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 22 07-21-2002 03:19 PM
