Old 04-11-2004, 02:43 PM
ordway ordway is offline
Question Help w/Fuel Filter Replacement! 1995 RS.
Symptoms: backfiring, coughing, choking, sputtering when I accelerate in lower RPMs-- like it's not getting fuel. Starts no problem and seems to idle normal. Tried putting in the moisture additive remover on the last tank to no avail. Air filter new.
So I bought a new fuel filter which is probably due, but I don't have a Chiltons and I noticed the filter is buried. Anybody got an FAQ for dummies on how to replace?
Buch obliged. MC
Old 04-11-2004, 02:56 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Help w/Fuel Filter Replacement! 1995 RS.
http://www.imagestation.com/album/?id=4291795981
Just for everone else... this is only for 1995.
For Sale 98 Eclipse GS, 5 spd
Old 04-12-2004, 08:47 AM
Thanks for the link. My knuckles are bleeding just looking at that install. Found a shop that'll put in my part for $ 70 which sounds reasonable.
So, just for a reality check, do those symptoms sound right to be pinpointing the fuel filter? I guess plugs could also be the culprit?
THX MC
Old 04-12-2004, 10:15 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
I'd replace the plugs too. it sounds a lot like that as well. besides... new plugs never hurt anyone.. especially if you never remember replacing them. Good luck.
V8's are like tampons, every pussy needs one!
Old 04-15-2004, 02:55 PM
I misdiagnosed the problem!
Quick update on this issue.
Turns out there was oil on the plugs causing the backfiring etc. So I returned the fuel filter, got a valve cover gasket and plug gasket kit, and had the work done by a local shop here in N. Virginia. Also had them go ahead and replace the plugs. The labor was $ 98. I supplied the parts. In the middle of it they called and said the PVC Valve needed replacing too plus a new hose.
That may be obvious to everyone else, but I'm a novice. The final tab for labor and the valve was $ 150. My parts were around $ 30.
Thanks for all the advice.
Old 04-15-2004, 03:36 PM
ashah000's Avatar
WOW! 150 for that damn you could of told us earlier there are write-ups on replacing it. It is really easy. I am going to replace mine tomorrow, I got my parts for 15.80 (and thats MOPAR OE too )
Well shit goes on and you learn from it, so who cares
92 Crown Vic, Need 2 replace FUEL FILTER... CrownVicChick Crown Victoria 4 08-15-2010 09:35 AM
Fuel Filter Replacement CCMphysician General Discussion 4 01-15-2010 04:27 PM
1982 E-150 Fuel filter HELP Evilfonzie Econoline 2 12-18-2009 11:48 PM
fuel filter replacment on RS coolguycooz Off-Topic 9 06-07-2005 08:07 PM
Fuel Filter replacement. FlossinPrimera Maintenance 4 09-23-2002 12:26 PM
