Old 06-06-2005, 09:15 PM
coolguycooz coolguycooz is offline
fuel filter replacment on RS
Ok i am replacing the fuel filter on my RS. I have to take off the battery and washer fluid tank right? well i have a problem i cant get the washer fluid tank cause the brake fluid beaker is in the way and i dont want to have to drain the brake fluid system how do i get it off? also the fuel filter is right behind the window washer fluid tank right?
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it")
98 GSX 5 spd. (Currently stock, spending all my mod money on body work.)
Old 06-06-2005, 09:57 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: fuel filter replacment on RS
first take out the battery and then the plate that it sits on (both the plastic and metal one). unbolt the brake fluid resirvor and also the washer fluid tank. you should be able to wiggle out the washer fluid tank without removing the hoses to the brake fluid resirvor. there's also a plug for the washer fluid pump that needs to be unplugged and you'll need to disconnect the fluid hose from the splitter on the hood. (keep the end of the hose above the outlet on the tank or you'll lose all your washer fluid onto the floor while replacing the filter). you should now be able to see the fuel filter. i would suggest un-screwing both connecting lines before unbolting the filter bracket. but let me warn you, you might want to set aside a good hour or two if this is your first fuel filter on your car. it's a bitch.
95 Talon TSI AWD
97 Eclipse GST
Old 06-06-2005, 10:11 PM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Re: fuel filter replacment on RS
I just did the FF in mine. I'm not sure the location of your's I think it's in the rear on teh RS. They aren't bad once you find out how it comes out.. It took me about 45 mins to do mine.. But mines in the engine compartment.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 06-06-2005, 10:38 PM
no it's in the engine bay, behind the battery/washer fluid resirvor.
95 Talon TSI AWD
97 Eclipse GST
Old 06-06-2005, 10:39 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
It would be the same spot. RS and GS's both have 420a's.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 06-06-2005, 11:44 PM
Killa's Avatar
Killa Killa is offline
it under the car , rear.
Old 06-07-2005, 06:29 AM
nova1313's Avatar
urban what I should have pointed out was that I don't have a 420a in my gs because it's a spyder.. I think that some of the eclipses not sure which years or models have the fuel filter in the rear. I know with the turbo's and 4g64 it's in the the front. I wasn't sure about the other two.
In any case to get mine out I pulled the battery. Released the top fuel line on it and let it bleed into a pan below the car. Prolly not the best way if you can find a way to get the fuel out otherwise let me know (depressurize the line somewhere?). If you take off the line going to the fuel rail you can just prop it up and it will stop leaking (yay for gravity).. The bottom one comes off a bit harder. I used two wrenched and squeezed to get it to turn. it too will let all the fuel that was in the filter out. Then it's two bolts to take off my firewall.
After that place the new filter in the bracket reconnect to the firewall, reconnect lines and replace the battery. i did this all without ever going under the car except for when i dropped my wrenches through. Some people suggest going from both sides so the bottom bolt is easier i'm not sure which is best... It didn't seem too difficult from the top.
Old 06-07-2005, 12:44 PM
Wow shit I should of realized that. I looked down and saw GS. LOL last week we just got done putting in a wally 255 afpr and return line and all thats shit. I feel like a dumb ass. I need to read things better.
Old 06-07-2005, 03:57 PM
nova1313's Avatar
no problem I didn't mean to make it sound harsh if thats how I cam across. I took it for a fact that no one saw my sig and just saw gs. I was just pointing that out.
Old 06-07-2005, 08:07 PM
i don't know what the hell you guys are on that say it's in the rear, but on my 95 rs it's in the engine bay.
95 Talon TSI AWD
97 Eclipse GST
