Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-14-2010, 06:50 AM
CrownVicChick CrownVicChick is offline
92 Crown Vic, Need 2 replace FUEL FILTER...
Can someone pls share instructions on how to replace the fuel filter? And what brand would you recommend?
Thanks a bunch,
CrownVicChick
Old 08-14-2010, 03:38 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 92 Crown Vic, Need 2 replace FUEL FILTER...
Jack up the vehicle and support it with jack stands. The filter is attached to the drivers side frame lust in front of the rear wheel. There are little white clips that need to be removed so the fuel lines can be removed. Then there is a little screw that needs removed to get the filter offl Here is a small picture.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-14-2010, 07:57 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
I'm not sure what the differences are between the 92-97 and the 98+ models, but on mine, I was able to remove it with a socket wrench (loosen the band holding it in place), and a flat head screwdriver to pry out the quick-release clamps.
I got a Wix filter for about $11 and it came with two new plastic clamps which just slide on both sides of the fuel lines to lock them in place.
If you just drove the car within the past few hours, pop the hood, open the fuse box, and pull the fuel pump fuse and crank the engine a few times. This will depressurize the fuel lines. Fuel will still flow out, mostly from the engine side. This is normal. Have a pan ready.
Here's a picture from a 1998 model.
http://p71interceptor.com/undercarri...1/PICT9652.jpg
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 08-15-2010, 09:33 AM
Thx 4 the post...I appreciate the info.
Thanks a bunch,
CrownVicChick
Old 08-15-2010, 09:35 AM
WOW, super helpful!! This car is going 2 be a project 4 me! So much work 2 be done. Thx again
Thanks a bunch,
CrownVicChick
Tags
fuel , line , system
