Old 04-10-2004, 08:53 PM
kimper kimper is offline
Angry leaky slave cylinder
Ok guys and gals, this one has been buging me all winter long. My slave is loosing fluid somewhere and I can't figure it out. Every morning before I go to work I have to fill up my clutch fluid because the resivoir is half empty after about 15 miles of driving. I have rebuilt it twice and checked the lines and the only part that is wet is at the very end of the slave where it pushes on the fork. I have had someone in the car and pumping the clutch and still have not seen a drop come out. Does anyone have any thoughts. O by the way this is a 95 ealgle talon AWD.
Old 04-11-2004, 02:05 PM
zr440 zr440 is offline
Have you checked the master cylinder?
Old 04-14-2004, 05:33 PM
Re: leaky slave cylinder
Yep and everything is dry except where I spill the fluid every once in a while
Old 04-14-2004, 08:22 PM
Is your interior carpet wet near the clutch pedal or anywhere in that area? If it was leaking I think that's where you'd notice it.
Old 04-28-2004, 05:13 PM
pntcfh2004 pntcfh2004 is offline
Send a message via Yahoo to pntcfh2004
clean up all the lines and the slave cylinder then add some kind of strong colored die then look for the leak
94 del Sol clutch, master cylinder, slave cylinder, battery problems marrathon6 Del Sol 3 11-22-2007 07:27 PM
slave cylinder or master cylinder wrenchboss26 Cherokee 3 05-20-2007 12:45 AM
Slave Cylinder/Clutch Return Cylinder Problem Geeko Cherokee 1 03-30-2005 08:09 PM
leaky slave unit ccartist Cherokee 2 03-28-2005 08:16 PM
Master cylinder - slave cylinder part sizzen56 Wrangler 1 12-23-2004 08:42 AM
