Old 04-10-2004, 01:17 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Help with Tamiya Epoxy Putty Quick Type
Well last night i put some putty on my S14 Silvia and this morning it was hard as rock. So i proceeded towards sanding. Problem is that the putty is sooo hard that not even my sanding files could sand it down good. I am using 180 grit which is the only one i find that could do anything to it since its soo hard. Anybody know how to get it just a tad bit softer so i could sand.
Thanks,
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 04-10-2004, 01:25 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Re: Help with Tamiya Epoxy Putty Quick Type
No clue how to get it softer. In my experience it's always quite hard. Just take your time sanding it. It's a nice putty since it isn't soft and crumbly, but does require some extra time to work with.
I work slowly!
Old 04-10-2004, 01:27 PM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
i had some squadron green putty that did that. it was so hard there was no sanding or filing it!! but i then got squadron white putty it works better....
i am not sure about tamiya, never used it before.
i would say bust out the dremel with a sanding wheel! hahah
Old 04-10-2004, 02:17 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
I've never used that kind of putty, but I did use 2-part automotive putty.
It dries hard as steel, but i used 200 grit with plenty of soapy water. It works wonders!
Give it a try, it might work.
Pedro
Click the picture to check my progress thread:
Old 04-10-2004, 02:40 PM
Fooesboy's Avatar
Fooesboy Fooesboy is offline
You can try applying the putty smoother in the first place, soke a cotten bud (q-tip) in lacquer thinner and wiping over the surface removing the bulk of the excess and smoothing the surface.......... then it's just pacience with sanding.
Old 04-10-2004, 03:37 PM
flyonthewall's Avatar
Car Mod guy
You won't get it softer. I never have problems sanding it, I use 240 for rough sanding and that works fine. Are you using fresh sandpaper? The problem with this putty is that it creates a fine dust which tends to clog the sand paper up quite quickly which then gives little effect. If you are sand a large area then the paper needs replacing often, alternatively, wet sand with wet and dry paper.
Old 04-10-2004, 04:07 PM
RallyRaider's Avatar
Zomby Woof
Too late now but what I do with the Tamiy epoxy putty is shape it with at knife before it fully hardens. Saves time and effort sanding it back a long way. Even once it is cured it is still able to be chisled with a knife before final shaping with sandpaper.
Old 04-10-2004, 06:38 PM
ImolaEK's Avatar
Re: Re: Help with Tamiya Epoxy Putty Quick Type
Thanks guys,
Chris: Yea i was trying to save up some sand paper by using the same one. Im half way through the pack already
Phil: Good idea, Im soo silly. How didn't I think of that
Here is a pic of where i was 3 hours of sanding ago
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
Old 04-10-2004, 10:21 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Change the brand of sand paper you are using. If it's meant for wood, that sand paper may not be hard enough for epoxy putty. Or, try using a coarse metal file to file or a hobby knife to carve it.
Hiroaki Fukuda
Old 04-10-2004, 10:38 PM
ImolaEK's Avatar
Im using the 3m sand paper from Auto Zone. I also used a sanding file and my Xacto knife to carve a little on my front
thanks,
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
Old 04-10-2004, 10:44 PM
AsongKar AsongKar is offline
Send a message via MSN to AsongKar
be patient when sanding...i believe you wanna get the job done fast...you can actually use grade 100 and sand with strength and fast speed...you will even scald your hand unknowningly
Old 04-11-2004, 06:46 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I know how you feel Joeham. I used to use the Tamiya Epoxy Putty and I tried to sand it. After an hour of sanding I havent gotten anywhere. You and I are so used to Bondo.
Get some 60grit sandpaper to do the main shaping. What you have now looks pretty good though!
Also, I have heard Evercoat Eurosoft is a lot like Bondo except it sticks to plastics, you might want to try that.
-Mike
Old 04-11-2004, 07:03 PM
ImolaEK's Avatar
Thanks Mike, that sounds awesome. Where could i find that. Does it include a liquid hardener like Bondo Body Filler. Does it come mixed?
Thanks,
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
Old 04-11-2004, 07:28 PM
mike@af's Avatar
Thanks,
Its a 2 part automotive filler (Catalyst/hardner and filler). Check an auto shop, Wally-World may have it.
-Mike
Old 04-11-2004, 07:43 PM
Blowncivic1320's Avatar
Blowncivic1320 Blowncivic1320 is offline
keep sanding joeham...keep sanding
hahaha
-Andrew-
Tamiya Epoxy Putty help! turbos86 Car Modeling 20 11-20-2005 05:38 PM
Easiest way of removing Tamiya Epoxy Putty? ImolaEK Car Modeling 11 07-08-2005 08:49 PM
Need help with Tamiya S2000 -> Spoon S2000 Race Car turbos86 WIP - Street 33 11-06-2002 08:33 PM
How do I dry Tamiya epoxy putty? rupertaker Car Modeling 6 05-30-2002 12:55 PM
Pls who can help with Tamiya paint awaken1973 Car Modeling 0 01-12-2002 12:52 AM
