Old 04-05-2002, 04:13 PM
rupertaker rupertaker is offline
How do I dry Tamiya epoxy putty?
After scratch building a few pieces, I can't get them to dry. Do I have to heat them up? Any tips? Thanks :flash:
Old 04-05-2002, 05:00 PM
turbos86's Avatar
turbos86 turbos86 is offline
Just give them a few hours and they'll dry. Depends on which type you are using. The normal type is ready for sanding in 12 hour (to be safe). Read the instruction sheet, it should say wait how long.
But if you soak the putty in water while mixing the 2 part together....they'll never dry (don't ask why i know)
Old 04-05-2002, 05:14 PM
Hmm....
I didn't soak it in water, but when applieing and shaping it, I did get my fingers damp so it wouldn't stick to my hands....Is this going to keep it from drieing?
Old 04-05-2002, 05:50 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Epoxy putty doesn't dry. It's not the type of putty, which solvent evaporates, but it hardens by chemical reaction. That's why it doesn't shrink so noticeably. It takes 4 - 12 hours depending on the brand, so you can have plenty of working time, unlike hobby putty or polyester putty.
Hiroaki Fukuda
Old 04-06-2002, 12:16 AM
Lownslow's Avatar
Lownslow Lownslow is offline
whaaaaaaaaaaa
i dont have the patience to wait 4 to 12 hours to sand putty then again im glad i still havent opened the bottle yet i still use good ol Dynatron and bondo putty it depends on how much hardner you mix with it that justifies youre working time.
DONT HEAT IT YOULL FRY THE PART
Old 05-30-2002, 10:59 AM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
i dun get how u would use plastic sheets with epoxy putty to make body-kits?
Old 05-30-2002, 12:55 PM
hirofkd's Avatar
http://www.asahi-net.or.jp/~xr2h-fkd...sp/333sp01.htm
This might be a bit overwhelming, but it's one way of using plastic sheet and epoxy to make a body. I haven't connected those separate pieces, but when I do, I use epoxy putty, so that they can be smoothly connected.
Hiroaki Fukuda
Tamiya Epoxy Putty help! turbos86 Car Modeling 20 11-20-2005 05:38 PM
Easiest way of removing Tamiya Epoxy Putty? ImolaEK Car Modeling 11 07-08-2005 08:49 PM
Help with Tamiya Epoxy Putty Quick Type ImolaEK Car Modeling 14 04-11-2004 07:43 PM
Tamiya Smooth Suface Epoxy Putty dannysreallycool Car Modeling 1 11-11-2003 04:59 PM
How to mix Epoxy Putty (pkw1?) Guiddy Car Modeling 6 12-22-2001 01:26 AM
