Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 04-10-2004, 12:00 PM
EvilAsh2000 EvilAsh2000 is offline
Send a message via AIM to EvilAsh2000
2000 headlight bulb help
Hey everybody i need somehelp. im haveing trouble replaceing a bulb on my 2000 eclipse, and was wonderign if somone could help me out. my problem is this i can disconect the connector. im worried if i pull it strait out i might damage something , if someone could give me step by step instructions that would totally kick ass. thanks
Old 04-10-2004, 07:28 PM
Zanark Zanark is offline
hey man I had the same prob cause I didnt have my manual on me, I just pulled it str8 out and it took some muscle but it came str8 out with some debri on it like metallic shit but its the only way to get the fucker disconnected. just make sure to line that rod thing right and remember how it was located cause you might end up turning the bulb the wrong way and have to redo the whole damn thing. Oh oh also theres like some spot you push on the thing to disconnect it I couldnt find it so I just ended up pulling the bitch really hard, worked for me just anylize it carefully.
Old 04-10-2004, 07:30 PM
oh yeahh you know that rubber peice just pull that back as far as you can and youll see what im talking about with that place you push It takes a little work mind you its not an easy task, took me 30 mins to just say fuck it and yank the fucker.
Old 04-10-2004, 08:06 PM
Re: 2000 headlight bulb help
hey thanks alot Zanark i eventually got it out it was a tough bitch , it would have been easier if i had like smaller hands though , haha thanks again bro
Old 04-12-2004, 04:37 PM
Fenixfire077 Fenixfire077 is offline
Send a message via AIM to Fenixfire077 Send a message via Yahoo to Fenixfire077
oh man, you guys are lucky, i ended up just rippin mine out and breaking the plastic hinge-point for the locking clip mounted on the actual headlight assembly, i had to use an oversized washer around that one screw in there to actually secure the bulb in, only to find out that the blue headlight replacements weren't bright enough for me. so i basically damaged my headlights for nothing.
Old 04-12-2004, 09:42 PM
Rulez Rulez is offline
Send a message via AIM to Rulez
There are little clips on the sides of the harness. If you squeeze those the bulb practically falls out.
Mike Rule
2000 Mitsubishi Eclipse GT Turbo
www.club3gfl.com
www.fiautosports.com
Old 04-13-2004, 12:21 AM
lol god damn Fenix man that sucks, and yeah I got lucky as fuck the damn bulb like had some corrosion around the bitch to and so did the wireing to, I had to clean the bitch and etc. and did any of you have trouble putting that rod back in place after you inserted the bulb? I ended up putting it back wrong and my bulb faced down and wouldnt illuminate all the way
Old 04-13-2004, 03:03 PM
00_GS 00_GS is offline
Send a message via AIM to 00_GS Send a message via MSN to 00_GS
Alright, i just changed my bulbs yesterday. I found that if you pull back the rubber piece enough to get the wire that is holding the bulb into place off, and then get the bulb and wire off, it is MUCH easier to get the bulb off of the wire harness! Then just put it back together like it was before, making sure the bulb has the three prongs facing up, right, and left as they were before... that way they wont be facing down or whatever!
Old 04-21-2004, 11:14 AM
RetroRacer02NY RetroRacer02NY is offline
Thanks for the help, I couldn't get mine out three months ago and haven't touched it since. Good thing I ran into this post.
1999 Chevy Prizm - Headlight bulb selection n1ckml007 Prism 3 10-26-2009 08:40 AM
Changing 96 Passat headlight bulbs. *Help Please* Trishtrash_69 '93 - '96 1 11-08-2007 08:16 PM
Headlight Bulbs Help darock8566 Cherokee 2 08-01-2006 12:36 PM
Replacing '93 Headlight Bulbs.......HELP!!!!! ksig449 Grand AM 1 07-23-2004 06:06 AM
