Old 07-23-2004, 12:07 AM
ksig449 ksig449 is offline
Replacing '93 Headlight Bulbs.......HELP!!!!!
Can someone please help me????? I need help replacing a headlight bulb on the passenger side of my '93 Grand Am. Is this something fairly simple to do? The high beams both work; it's one of the low beams that is out. I don't have a manual so I can't look in that. Do I have to take out the whole headlight assembly or do you just unscrew the "thing" holding the bulb and pop it out?
Old 07-23-2004, 06:06 AM
Gatesy Gatesy is offline
Re: Replacing '93 Headlight Bulbs.......HELP!!!!!
Just grab it from behind and twist it and i pops out, but if you don't haave small hands it's kind of annoying, I just grab the wire and pull on it a little to twist the bulb loose, then it just pops right out then there's a little clasp you have to pop up to pull the blulb out and if you have a little trouble getting it out (for space reasons) it will take a little bit longer to get it back in.
