Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-10-2004, 11:49 AM
motormike40 motormike40 is offline
Send a message via AIM to motormike40
how hard is it to tune a turbo carburated car?
if you boost a carb car how hard would it be to fine tune it. And can u boost with a stock carb.
Old 04-10-2004, 01:19 PM
SaabJohan SaabJohan is offline
Re: how hard is it to tune a turbo carburated car?
The carb must be modified, a better fuel pump will probably be needed and a fuel pressure regulator must be used.
Old 04-27-2004, 02:44 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
you've also got to pressurize the entire carb (inside/outside) by boxing it in...
if not, the pressure on the outside would kill your float bowls.
Old 04-27-2004, 05:40 PM
Jusliwood Jusliwood is offline
If the car originally has turbocharger it is very easy. You can get extra HP tuning the screw of CO carburator ( in order to avoid knock ) and the nut of the waste gate turbocharger.
But If the car has an atmosferic engine you must modify many parts (exhaust mainfold, cylinder compresion ratio, carburator.......)
