Old 04-10-2004, 08:53 AM
turbo type-r's Avatar
turbo type-r turbo type-r is offline
Question clear hoods
ive seen these on the little diecast modifiers can i do one on a 1/24 scale car and are they just made from clear styrene
are they fiberglass
lac - 80 % done baby!
Old 04-10-2004, 09:31 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Re: clear hoods
They're molded plastic.
nightmaR3Z
Old 04-10-2004, 09:33 AM
Re: clear hoods
where can i get one
Old 04-10-2004, 10:19 AM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: Re: clear hoods
Originally Posted by turbo type-r
where can i get one
Jamaican model black market.
Ok, actually, no one that I know of manufactures and sells clear hoods. You can find them occasionally in a kit, the Tamiya Skyline R32 comes to mind, but they aren't commonly included in kits like that. The issue here is the clear plastic, it is very hard to make them in resin (clear resin, as I understand is a beast to work with) and most aftermarket companies to not have the resources to make them from injection molded styrene which would be the ideal material. The last option is to vacuu-form it yourself. Do a search, beleive it or not somewhere around here there is a whole thread all about making clear hoods.
Old 04-10-2004, 10:25 AM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
Re: clear hoods
I have the falken skyline and the 300zx and both have clear hoods. I was thinking of doing one of them with a clear hood painted clear blue or clear red.
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
Old 04-10-2004, 11:06 AM
JaDa KrAfTmEn JaDa KrAfTmEn is offline
Re: clear hoods
make one with a cd case tracke the outline and cut it up..its just like making the bedcover
Old 04-10-2004, 11:37 AM
gasman03's Avatar
gasman03 gasman03 is offline
The upcoming Revell plastic 99 Eclipse, 93 Civic and CRX will come with clear hoods
Old 04-10-2004, 12:16 PM
Re: clear hoods
i wanna put one an my hatch
jada kraftman - you cant because most hoods are curvy and have shape to them with a cd case its a flat surfice
Old 04-10-2004, 12:27 PM
clear hood
Actually u can do it Turbo
Dont say u cant wen u ask a question and i say that u can
Description: How to make custom taillights... Windshields... Headlights... hoods and anything else that has to do with "glass" on your diecast
Materials:
• CD Cases-The best plastic I have found. They are the perfect thickness for the windows and lights.
• Piece to modify/change
• Pencil or fine point marker
• Kitchen Pan
• Boiled water
• Wet Sandpaper 2500 grit (OPTIONAL)
• Polishing Compound (OPTIONAL)
Directions:
1. Take what you want to change or modify
2. Put a pattern on the CD case.....
3. Cut it out VERY CAREFULLY!!!! The plastic cracks easily
4. Once you’re done cutting it out get a Pan from the kitchen...
5. Boil some water.... like 1 inch in the bottom.
6. Get a spoon that sits on the ledge of the pan and has some water in it...
7. Put the piece in the spoon that is in the boiling water until it is soft
8. Bend it to shape... It should be clear. And fit perfect if done right.
If it’s not clear
1. Wetsand it with like 2500grit sand paper
2. Then polish it with something
3. Put a coat of clear coat for shine
Old 04-10-2004, 12:30 PM
chinesechickens's Avatar
chinesechickens chinesechickens is offline
google is your friend
do a search on google:vacuum forming
i just did and it came up with plenty of tutorials on vac forming...
also try this link, pretty good shows you how to make your own vac form machine.
http://www5a.biglobe.ne.jp/~am-kish/...ng-diary3.html
hope this helps some
chris
Estella warren is hot!!
Power is nothing without control
I thought i saw a v-spec II, i did i did. i did see a v-spec II!
Old 04-10-2004, 12:34 PM
ProSStreet's Avatar
ProSStreet ProSStreet is offline
Re: clear hoods
I dont understand the purpose of a clear hood.
If you want to show off your highly detailed engine cant you put the hood up? or take it off?
I dunno maybe its something else, can anyone fill me in?
Old 04-10-2004, 12:51 PM
i have seen some fullsized show cars with clearhoods.maybe they want to replicate this????
i don know.....
chris
p.s. off topic:a while ago i had a toon of a muscle car doin a burnout with a tiny japanese car between its rear wheels somehow i lost it and need it back does anyone have it?
Old 04-10-2004, 01:29 PM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
Re: clear hoods
make one,use thin plastic and glue it on
Old 04-10-2004, 01:40 PM
Re: Re: clear hoods
i looks really cool and custom and it got that " look at my hotness " look
Old 04-10-2004, 01:42 PM
Re: clear hood
Materials:
• Kitchen Pan
• Boiled water
Directions:
If it’s not clear
thanks im gonna do one on my hatchback now
Clear Hoods. (Painting them)Help Nissan~Guru Car Modeling 2 02-09-2005 08:20 PM
How to make clear hoods? DJSurfer616 Car Modeling 7 03-21-2004 09:54 PM
My first clear hood DSi Graphic Manipulation 1 03-22-2003 02:20 AM
ummm,,,,,,ahhhhh,,,how do i paint a clear hood chevyeuro93 Car Modeling 21 03-16-2003 06:23 AM
Kens Clear Hood 4mula Graphic Manipulation 1 02-22-2003 02:29 AM
