Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-09-2004, 08:57 PM
adrian3a adrian3a is offline
camry 89 2.0 4 cyl OIL LEAK!
i have a camry 89 that has a bad oil leak. It only leaks when the engine is running and for about 5 mins after its off. I had the valve gasket replaced already, but it is still leaking. Can anyone tell me what they think it might be? and maybe how hard of a job (and estimate of $$) it would be? Thanx.
Old 04-10-2004, 12:05 AM
Joe W Joe W is offline
Re: camry 89 2.0 4 cyl OIL LEAK!
You could check the oil pressure switch.Not sure where it is on your car,but just look for a sensor screwed into the engine with an electrical connector on it,and see if there is an oil trail.
Old 04-10-2004, 01:57 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Where exactly is it leaking from? Bottom? Top? Left? Right? Front? Back? Give us a clue. If you don't know, make a point of figuring it out or have someone figure it out for you.
2001 2.0 Jetta with 5 codes???? moemo '97 - '03 1 12-29-2009 06:22 PM
need vacuum diagram:'88 ram d-50,mitsu 2.0 liter cukoobajube Ram Pickup | Ram SRT10 0 05-31-2009 06:59 AM
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 01:44 AM
01' grand am 4 cyl. oil leak 1s1kbaddog Grand AM 3 12-22-2008 04:44 PM
96 camry 2.0 engine sound is rough BRijesh Camry/Camry Hybrid/Vista 2 07-04-2004 01:52 AM
