Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-09-2004, 05:13 PM
boarderbrad158 boarderbrad158 is offline
Send a message via AIM to boarderbrad158
Cool 200+ hp d16?/ b16 or b18 swap?
Is a d16 from a 99 civic ex capable of having over 200 hp? if so how much would the parts cost. also would a b16 be a good engine to turbo, or is a b18 be a better choice? how much would a b16 cost compared to a b18
Old 04-09-2004, 06:28 PM
liquidflame8 liquidflame8 is offline
Re: 200+ hp d16?/ b16 or b18 swap?
there is about a 1k difference between the b16a and b18c1. the b18b is good for turbo and it's similarly priced to the b16 but has 1.8L displacement.
Old 04-09-2004, 08:14 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the LS motor, b18 is better for a turbo setup as it already has low compression, which is easier to tune, then to have a high compression turbo'd motor.
go with the b18.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-09-2004, 09:30 PM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
I'd beef up the d-series and turbo the hell out of it...but thats just me...i've seen lots of d-series motors with stock internals at about 8psi over 200hp
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 04-10-2004, 02:05 PM
jajimo's Avatar
jajimo jajimo is offline
Go with the F20B and supercharge it =P
Old 04-10-2004, 02:12 PM
XixGenuinexiX XixGenuinexiX is offline
i doubt with 8psi you'll get 200whp on a d-series engine. But it might be doable (is that a word) with a big ass turbo like a t3/to4e. But anything higher than 200whp on a d-series and i think you should rebuild the engine with quality parts like Piston, sleeves, etc.
Old 04-10-2004, 04:38 PM
would there be a big hp difference between a turbo b18 and turbo b16?
Old 04-10-2004, 06:21 PM
Basically the B18B(LS Integra) will have more torque than a B16, but the B16 will have more hp at the same PSI level if the same turbo is used. But the B18C1(GSR Integra) will have more hp, and more torque than the B16(SI Civic)
Old 04-12-2004, 04:53 AM
but you can add psi and displacement is harder to add. stroker kits are EXPENSIVE. and it already has low compression pistons which you would probably add to a b16
Old 04-14-2004, 10:55 AM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Yeah Go with the B18b integra LS motor. It is priced right around the B16 range and you wont need to throw pistons in to run a med. boost ammount like the b16. Still I would only run 8psi on it. The D16 could be nasty but you would need to rebuild the ENTIRE motor in order to puch about 15psi thru it in order to get it into a plus200hp range. I mean i have 15psi onthe street in my b16a2 but i also have 10k under my hood...do i think about maybe i should have gone a b18b route sometimes.......yes. so go with the B18b integra LS motor...There is a reason why the majority of us have told you to go that route...You will be happier come the long run
Old 04-14-2004, 05:22 PM
thanks guys, i think you sold me on the b18 ls.
b16 to b18 swap ecu question nightkidEf9 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-01-2006 03:50 AM
Best motor to swap into a 4G? B16, B18, B20/vtec, ZC, D16? bambam89lx '88 - '91 Civic | CRX | Wagon | Shuttlee 68 05-05-2005 10:09 PM
D16 bottom, B18 top SinisterMotorsport '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 17 10-16-2004 04:57 PM
b18 swap with b16 tranny ? SlowerCivic JDM Motor & Parts info/chat 1 10-14-2004 03:14 PM
