Old 04-08-2004, 06:06 PM
str8chevy str8chevy is offline
Send a message via AIM to str8chevy
Lightbulb HELP WITH '89 1500 4.3L....idle speed
Can someone please tell me how to adjust the idle on my v6 chevy truck it idles way too high and I cant figure it out.......id really apreciate the help thanks.......Tim
Old 04-08-2004, 08:20 PM
Lightbulb forgot
forgot to say it has electronic fuel injection
Old 04-08-2004, 08:39 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
assuming there is no vacuum leak or stuck/binding linkage, I would suspect the IACM. if you come to a stop when hot and go into N, does it idle high for 30 seconds then turn the SES on?
Old 04-27-2004, 09:07 PM
327-C1500 327-C1500 is offline
Re: HELP WITH '89 1500 4.3L....idle speed
Try the instructions at this page...
http://www.california.com/~eagle/howell.html#idle
Old 04-27-2004, 10:10 PM
406Elcamino 406Elcamino is offline
Check the gasket on the bottom of the throttle body. Bad about breaking and sucking in. Makes a big vacuum leak and high idle.
Old 04-28-2004, 12:55 PM
BobM46128 BobM46128 is offline
You can also get the idle set by running the engine until warm. Then pulling the vacuum hose from the brake booster while the engine ids running. This will make the IAC go to full closed. Pull the disconnect the IAC wire and then plug the vacuum hose back in. Adjust the idle screw to make the engine idle while in neutral or park. Then reconnect the IAC valve wire. This should make it work properly.
As a matter of preference, I always hook/unhook the wires with the engine/power off whenever possible.
2004 ram 1500 4.7 overdrive and idle issues mrwrench Ram Pickup | Ram SRT10 2 06-03-2010 10:22 AM
90 s10 blazer 4.3L stalling, erratic idle.. please help! gunner0352 Problem Diagnosis 6 09-18-2009 08:31 PM
Help with distributor 95 4.3L msfan324 Problem Diagnosis 36 06-21-2009 06:22 PM
98 2wd 4.3 dual exhaust jesse938 C/K 3 05-17-2009 12:37 PM
1992 2.3L Quad 4 HO Idle Speed???? TransAm_Ownr Grand AM 4 10-29-2004 01:08 PM
