Old 04-07-2004, 10:51 PM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
clear coat before or after window trims
i read the couple tutorials on window trims but said nothing about clear. should i add my window trim then clear coat or clear then mask ti off and sand my window trims and paint them black or just clear and mask and paint? what one? i am delaying on doing it becuase it is my first try and i want to knwow hat do do before i start
Old 04-07-2004, 10:55 PM
gasman03's Avatar
gasman03 gasman03 is offline
I do it after, no reason why, just the was i've always done it
Old 04-07-2004, 10:57 PM
supermod04's Avatar
Banned
Re: clear coat before or after window trims
ok, cus i ahve always seen ona real car they are flat and not very gloss, so i figured after i clear would work
Old 04-08-2004, 07:05 PM
Fastphil's Avatar
Fastphil Fastphil is offline
Yeah it depends on the finish of the 1:1 car. Like if it's chrome, then you can clear after, no problem. If it's flat or semi-gloss black, then clear first, and carefully apply the trim.
Old 04-08-2004, 07:30 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
I never understood why you clear before or after for that matter...
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 04-08-2004, 08:09 PM
supermod04's Avatar
Banned
well i got it, i decided to do the trims first. coupel peopel said thats what theyd o so i will use that method. hey it is my first time for window trims so i will experiment this time
Old 04-08-2004, 08:26 PM
Vric's Avatar
Vric Vric is offline
I do it after. Shiny black for trim don't look great at all
Old 04-08-2004, 09:06 PM
supermod04's Avatar
Banned
2 late i guess it will be shiny, well i used gloss black paint any ways, and 5 people said after so hey i will go with that
Old 04-09-2004, 08:17 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
On a car that needs a clear coat, I always apply the clear before doing any trim work like windows, etc. The best reason? The clear will help protect the body color from masking. Peeling body paint up with the masking is a b1tch!! Also, depending on what you're using for clear, if the trim painting goes badly (leaks, bleeds, whatever), and you need to correct an error, the clear will protect the body color when you clean up the trim.
Doesn't matter what color the trim is with regard to when you clear coat- if it's flat or gloss, than paint it flat or gloss.
With as annoying as window trim painting can be, it's nice to have a few advantages.
Old 04-09-2004, 08:19 AM
supermod04's Avatar
Banned
well i got the widnow trims thanks guy. i did it before cleawr. i think on my next model i will do it after. i did not even mask it, i use a testors paint pen worked great
Fkouch's Avatar
Fkouch Fkouch is offline
Re: Re: clear coat before or after window trims
Yeah well it'll look crappy. In fact if your paint job is glossy enough you don't NEED a clearcoat at all. I only use a clearcoat on metallics.
Also remember that if you wait too long (or not long enough) to clearcoat your model, the clear layer might have problems and may even crack.
As long as you get 1 or 2 good wet coats of paint on you shouldn't need a clearcoat. Go have a look at PMans stuff for example.
Cheers
Farrokh
Current Projects
Yamaha YZF-R1 Taira 70% complete
Lamborghini Diablo SE30 (Fujimi/Revell combi) 20% complete
Tamiya Ferrari Enzo plus SMS, Sakatsu and Acustion 10% complete.
Old 04-09-2004, 08:26 AM
MPWR's Avatar
And NEVER clearcoat after the windows have been installed!!
Old 04-09-2004, 08:37 AM
supermod04's Avatar
Banned
it acuallty looked nice, the windows trims are a little dull, i use the clear cus with my old experince of modeling from about 4 years ago, i have a couple models with no clear and the paint jobs are dull, they got dull sitting for over 5 years.and, the paint is a metalic piant, i mixxed myself. but the reason i cleared after windows trims is i talked to about 5 or 6 people on aim, asking them and knowing there model skills and how well there models turnout, i did what they said, plus this is my first model in over 5 years, and before never did widnow trims, so hey it was a practive and learn thing. ow next time i will be doing window trims after clear.
so this is one of the learn and try things for me. i will do diffrent on my next model, experiment with what i can do.
thanks for the help
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
Before or after clear coat? Kiss My Axe Car Modeling 5 09-29-2006 11:40 AM
Metal transfers before or after clear coat? MikeWz Car Modeling 3 08-18-2005 01:53 PM
clear coating before or after? sportsfreik3099 Car Modeling 3 01-07-2005 05:19 PM
Clear Coat On The Windows Magyar1 Car Modeling 5 04-27-2004 08:01 PM
