Old 08-18-2005, 09:36 AM
MikeWz MikeWz is offline
Send a message via AIM to MikeWz
Metal transfers before or after clear coat?
I know you put the decals on before clear coating, but do you put the metal transfers on too?
Current Model: Ferrari F50
Old 08-18-2005, 09:47 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
It's your call, after all, it's your model.
If you put them on after the clear it will look more realistic.
I know some people who use a thin coat of clear to seal them on since they can get knocked off while dusting and such down the road.
They were intended to go on after clear coating... - Mark
Old 08-18-2005, 01:35 PM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Re: Metal transfers before or after clear coat?
Personally I'll be putting my metal pieces onto the body after the clearcoat. I also put my decals on after clear, they go on easier & then I don't need to worry bout the clear eating my decals.
Old 08-18-2005, 01:53 PM
THEciarr82 THEciarr82 is offline
Whenever possible i like to put them on after for the realism factor stated by S-Master above. If I can, like to drill a hole where the PE will go and CA from the other side (inside or bottom - where its not visible); I think that is common procedure but worth mentioning
