Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-07-2004, 10:30 PM
HARDTIMER HARDTIMER is offline
Has anyone ever ran out of gas?
Just wondering. I did a lot of running around today and was a couple lines above the empty mark when my car ran out of gas on me. I KNOW I KNOW but I was only a couple blocks away from a good gas station and I figured I had a enough gas to pass up all those cheapy stations because i dont use "shit gas" as indy refers to it LOL. Anyway, called auto club and they gave me gas and it started right up. Quesiton is, by it being "NOT ALL THE WAY EMPTY" could I have a gauge problem or something else or is this the way these cars are? Car started right up and drove pretty good to the gas station but do you guys think I may have damaged anything??? I also noticed that when the tow truck guy put the gallon or so in the tank, when I started it, it was at the 1/4 mark!!!!!!!!!!!! And my fuel range was 68miles!!!!!!!!! WTF?????
Old 04-07-2004, 10:52 PM
curtain curtain is offline
Re: Has anyone ever ran out of gas?
I had similar experience. Running from couple of lines above empty mark to below the mark till I found a gas station finally.
Warning kept on beeping, the "Service Engine Soon" light on.
However after I filled the tank, everything's OK.
Never drive if the oil is low. The Olds Aurora eats fast than you thought.
Old 04-07-2004, 11:08 PM
yeah, now I know!
Old 04-08-2004, 12:11 AM
Green Machine 95 Green Machine 95 is offline
Send a message via AIM to Green Machine 95
Well, in a lot of cars when its at the 1/4 mark its not really a 1/4, because the needle goes way past F.
If I were you I would add in some Fuel Injector Cleaner on a full tank of gas.
95' Aurora: Luxury at its best, with a little speed on the side
www.smorgas.com/awnawhellnaw
Old 04-08-2004, 12:32 AM
will do thanks alot.
Old 04-08-2004, 09:07 AM
RoraStar96's Avatar
RoraStar96 RoraStar96 is offline
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
The Aurora is simply amazing on gas on the hwy, 4000lbs at 80 mph, most of the energy is momentum, however, hauling 4000lbs around in the city and its gonna eat.
Typically on my car, the gas gage sits WAY past F for almost 90 miles before it his the F line. Bearing that in mind I make a habit of not letting it get past 2/3 empty. NEVER a good idea to let the fuel run low consistantly unless you want to be changing your fuel pump in the near future. That pump needs to stay cool and lubricated with fuel at all times.
Don't run out of gas anymore!
Heed the low fuel range warning on the DIC too...its very handy!
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
Old 04-08-2004, 10:04 AM
yes, I have learned my lesson, the tow guy thought my girlfriend did it since she drove where I was to sit w/ me and I was so pissed. He assumed I drove our other car to sit w/ HER. I know he couldnt understand why I/HER passed up the AM/PM mini market gas station back 2 blocks!
Old 04-08-2004, 02:26 PM
RoraStar96's Avatar
LOL...
Bad day?....
Old 04-08-2004, 02:54 PM
yeah!! Jim, what color is your aurora? White or gold? looks white but then again sort of gold. Im guessing the pearl white?
Old 04-08-2004, 03:22 PM
ugsrich ugsrich is offline
When the Aurora was first introduced back in '94 I recall reading a review that spoke specifically about the fuel gauge's non-linearity at low fuel levels. The article addressed the accelerated decline of the guage from the 1/4-level to E as compared to its 3/4 - 1/2 change. So, from this early review it sounds like there is some inherent inconsistencies.
The reason why your's seemed to indicated that you had fuel when in fact you did not seems inconsistent with this review. Conversely, my '95 acts almost identically to the review's claim.
Old 04-08-2004, 03:47 PM
Hmmm, well I know one thing Im not letting it get lower than the 1/2 mark again. NOT WORTH THE TROUBLE/DAMAGE/$$$$$$$$$$$$$$$$$$$$$$. Although, the way the gas prices are in southern ca. A repair may be cheaper than a tank of gas!LOL
Old 04-08-2004, 06:14 PM
RobertHammen RobertHammen is offline
I think GM calibrates all of their fuel gauges this way... it's a psychological thing to keep the gauge on full for the first 90-100 miles, as AuroraStar said, and then plummet like a rock.
I personally fill mine up at the first opportunity when it gets into the yellow (1/8) zone on the gauge (i.e. DIC dings - can't stand that). In wintertime, I refill anytime I get near 1/4 tank. You're absolutely right, you don't want to do this very often as it can kill your fuel pump (which is another known failure point on Auroras - one fellow on another board had his die in the middle of the Holland Tunnel - yikes!)
Old 04-08-2004, 07:30 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
well if i were you since you ran out of gas replace your fuel filter
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 04-09-2004, 10:01 AM
RoraStar96's Avatar
Very good advice...who knows what kinda grit got pushed thru the fuel lines when the tank went dry...btw where is the fuel filter on these cars?
0.0
Oh and Hardtimer, shes diamond white
1997 Aurora
"Aurora Snow"
Old 04-09-2004, 12:04 PM
cmdrgala's Avatar
cmdrgala cmdrgala is offline
Send a message via Yahoo to cmdrgala
Cool Car only holds 18 gallons
Hardtimer:
The car only holds 18 gallons,when the low fuelloight comes on,you maybe have 25 to 30 miles before your out of gas.
Anytime you reach a quarter, save the grief and get your beast filled up.
"Driving Along in My Oldsmobile"
How many miles has anyone ever got out of the 4T60E trans smantas Eighty Eight 11 04-01-2008 07:12 PM
Has anyone ever maxed out there 550cc injectors? soyee7 Off-Topic 2 09-22-2005 05:34 PM
anyone ever ran straight pipes on a cavalier? KustmAce Cavalier 10 04-18-2004 08:56 AM
