Old 04-07-2004, 08:38 PM
joshintally joshintally is offline
'97 s-10 2.2 alternator replacement
I've got 94K miles and today the voltage meter dropped to about 10 and the battery icon lit up. I'd replaced the battery less than a year ago so I figure it's time to swap the alternator. Can anyone please give me some tips on getting this done with a minimal amount of frustration?
Old 04-09-2004, 12:41 AM
jakedubb's Avatar
jakedubb jakedubb is offline
Help is here.........
1) Disconnect neg. battery cable
2)Remove the nut on the output stud of the alt. (this will have the + battery cable and one or two smaller wires connected to it)
3)Disconnect the wires after removing the nut.Just let 'em hang.
4)Remove the snap-in plug on the side of alt. (should have a brown wire in it)
)Loosen Lg. bolt on alt. (leave this in place until later after loosening)
)Remove bolt from alt. mounting bracket
)Remove bolt from front side of alt (near serpentine belt)
)Loosen the tensioner pully bolt. DON"T REMOVE THE BOLT! Just loosen it a bit until you can push/pull on belt tensioner. This allows you to remove belt from the alt. pully
6)Slide belt from alt. pully HOLDING ALT. IN PLACE W/ OTHER HAND OR W/ HELP
7)Remove lg. bolt and alt.
Need help? PM me and I'll walk ya through it. Good luck,hope it helps.
1996 S10 2.2 Liter w/ 4/5" Belltech drop, 18" Boyd Coddington Magneatos on Yokohama Parada Spec-2 tires, elect. fan, Gibson catback, racing seats,Optima Yellowtop,2 dvc Alpine Type R 10" subs, Memphis 1000D amp (1100 watts mono),Rockford Fosgate 201S (mids/tweets), Extang Tonneau, shaved tailgate, rollpan, 20% tint, painted dash bezel & misc int., Viper 800 ESP, 100% chrome grill, Street Scene grill inserts, diamond clear headlights, Goodmark Ram Air hood (gen. 3).
Old 04-09-2004, 12:44 AM
jakedubb's Avatar
Re: '97 s-10 2.2 alternator replacement
Oh ya,
8)Throw the piece of sh!t 105 amp alt. away and get a high output alternator! I had the same prob. not to long ago
Old 04-12-2004, 04:59 AM
Lightbulb Re: '97 s-10 2.2 alternator replacement
Perfect - one other thing that helped was removing the coolant reserve tank (and the computer module above it) to get easier access to the alternator. The extra hand space was very handy...
Old 01-15-2005, 07:18 PM
calikid calikid is offline
Re: Re: '97 s-10 2.2 alternator replacement
That's the real tip, thanks. I don't think you can get the alternator out of the engine bay w/o removing the coolant reserve tank, and the extra room more than makes up for the small amount of time it takes to pull it.
Also, the tension pulley has a square hole in it to fit a socket wrench. Use this to move the pulley to remove/install the belt.
Old 01-16-2005, 03:05 PM
mycobra70la mycobra70la is offline
I pulled my fan shroud which was like two bolts on top and two half way down on side. Opened up the area quite abit. Mines a 96 same
1997 Chevy S10 2.2 Starts Then Dies Logan76 S-10 9 07-29-2010 03:44 PM
Need help 97 2.2 front pulley bracket salon1978 Problem Diagnosis 2 01-05-2010 09:48 AM
alternator replacement, help please? blsbrandy Windstar 19 10-03-2009 07:00 AM
GM 2.2L OHV DOHC: Interference or NON-Interference sharpnshine General Discussions 1 04-27-2009 07:21 PM
no start 95 cavalier 2.2 jeffyweasel Cavalier Problem Diagnosis 2 03-14-2009 06:12 PM
