Old 09-05-2009, 04:20 PM
blsbrandy blsbrandy is offline
Angry alternator replacement, help please?
Trying to change alt in 95 windstar 3.8L, can't get to the bolt to loosen on tensioner arm, it's a very tight spot, can't fit a ratchet in there, plain old wrench slips off, any tips or suggestions?
Old 09-05-2009, 05:52 PM
wiswind wiswind is offline
Re: alternator replacement, help please?
What I have done is to grasp the belt and just pull hard on it to get the slack to move it off of the alternator pulley.
I have used a 15mm wrench on the bolt on the pulley....but it is a hard place to get to.....
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 09-05-2009, 11:57 PM
Thanks, I'll try.
Old 09-06-2009, 07:04 AM
I also found that a ratchet does not fit.....but use a box or open wrench on that bolt.
There should also be a square hole in the tensioner that you can put the square part of your ratchet in.......if you can get at it.
The tensioner is certainly not in the most convenient location.
1996 3.8L Windstar
Old 09-06-2009, 09:58 AM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Are you trying to get to it from the top? Iknow mine is different year, but I was able to get to it crawling under and reaching from the bottom. Maybe that could work for you too!
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 09-06-2009, 01:29 PM
Gobbler865 Gobbler865 is offline
I found that after removing the negative battery cable, for safety, and then grasping the long stretch of the belt and leaning back, it gave me enough slack to work the belt off the alternator pulley.
Old 09-07-2009, 11:53 AM
Ron AKA Ron AKA is offline
My 98 Windstar eats alternators, and I've lost count how many times I've changed it. You just put a wrench (no room for a socket) (I believe 15 mm) on the back pully. With your left hand pull towards the front of the vehicle. This will loosen the belt enough to slip it easily off the pully at the front with your right hand. There is no need to play with the tensioner. Assembly is just the reverse.
Old 09-08-2009, 07:40 PM
AvalonJohn AvalonJohn is offline
Guys:
I think my alternator maybe on the brink ?? I will put a new one in my 99 Windstar with 3.8 liter. I will put in a 135 amp since my son will get it next year and will be playing the radio and cell in there. What is the best one (Make & model) to put in ?
Thanks,
AJ
Old 09-08-2009, 08:06 PM
I have the new unit from Advance Autoparts.....they sell a remanufactured and a new one.
If your battery is not pretty new......I would replace it as well.......
In any case, new or not, your battery should be checked out.
A defective battery can place a serious load on the alternator......and burn it out.
I just looked it up.....1999 3.8L uses a different altrnator from my '96 3.8L.
New is about $210, Remy, for the '99.....at the Advance Autoparts website.
It was under a different brand name (although could have been same unit) about 4 years ago when I bought mine.
Same brand is a little more from Rockauto.
I get the same price (around $210) at the Oreilly and AutoZone websites.....although AutoZone shows it a special order for my area.
Again, this is the new unit.
1996 3.8L Windstar
Old 09-09-2009, 08:45 AM
Originally Posted by AvalonJohn View Post
Guys:
Thanks,
AJ
AJ,
I just went thru this with my '99 3.8L. My particular model uses the 135amp (there are 2 for that year a 110A and 135A). Check to see if your battery is good first. I found that I was chasing my tail and not running simple voltmeter checks which would have saved me oodles of time. I was lucky that it was just my battery and luckily it was still under warranty so it only cost me $37 for a Duralast Gold from Auto Zone. If the battery is no good and you throw in a new alternator, you run the risk of damaging the components inside the new alternator and wind up dropping more money than you need to.
If you run by AutoZone or AdvanceAuto, they will hook up your battery, while still in the car and check both the non-load voltage and then heck your charging system. You might just find that our battery is the culprit and not your alternator.
Just my
My hard lesson learned here is a few extra minutes doing the electrical checks can save a bunch of time on the backend of labor.
Mike
Old 09-15-2009, 04:40 PM
Thumbs up Re: alternator replacement, help please? UPDATE!
Finally got it, Used the "wrench with a pipe on it for leverage" method, the pulling on the belt didn't work for me (or my man, who's much stronger). Thank you so much everybody.
Old 09-15-2009, 06:05 PM
tomj76 tomj76 is offline
Moot point, but I've used a 6-point combination wrench on the pully bolt to do it.
Old 09-15-2009, 09:00 PM
12Ounce 12Ounce is offline
When replacing the alternator for my '99, I was surprised to find the dealer had the highest amp unit .... at a price lower than any of the "usual" local aftermarkets.
Old 09-18-2009, 09:04 AM
Erik2002Winnie Erik2002Winnie is offline
I have an 02, so it might be different.
jack car, remove passenger wheel.
get at it underneath with the square end of a ratchet. IF that doesnt work, get it off somehow and replace the tensioner.
it takes a little muscle, but it its near impossible, somethings wrong.
dont even try from uptop. theres just not room.
again this is my 02, a older winnie may be different.
edit, sorry didnt see you got it.
using a pipe works wonders, my floorjack handle comes aart in two, and i usually use that.
Old 09-26-2009, 06:41 AM
yudyj yudyj is offline
Here is my experience...I have a 2000 Winnie. The van is 10 yrs old and about 70K on it. Was thinking of changing the belt and started reading this thread. The best for me was to take the front wheel off. Then the tensioner was quite easily accessible from below. Used a simple 13mm wrench to move the tensioner while some one removed the belt from the Alternator pulley. The alternator has three 15mm bolts all easily removed from the top. I bought a brand new one from Adv Auto made by Remy. It was only $30 more than the remanufactured one.
Tags
alternator
