Old 04-07-2004, 11:59 AM
RochelleC RochelleC is offline
Question Vent lo-hi does not blow
when I use my vent it does not blow. Although I feel warmth coming through when I use it in 'hot' for cold mornings, when I change it to high... I can not tell a difference. Is this a minor repair?
Old 04-10-2004, 12:08 PM
www451oa www451oa is offline
Re: Vent lo-hi does not blow
I had a similar problem. I had changed the blower switch with no success. Ended up that I had to change the selector switch to control the Def, Htr, Vent, A/C, ect.
first of all, to trouble shoot, take a wire and run it directly to the positive on the blower motor. if the blower motor is good, it'll blow full power. That rules out a dead motor.
It should be a minor repair, sounds exactly like my problem, I also had a small amount of heat, but that was just the heat in the duct going upward.
Now for a temporary redneck fix, until you have the time to fix the problem correctly, and allowing you to have heat. you can bypass the interior switches all together. Again, this is TEMPORARY. Take a wire connected to POS terminal, run it along the fender out the hood, and into the truck, connect it to a standard light switch, then run another wire from the light switch to the POS connection on your fan motor. Yes this is VERY redneck, but it will give you heat until you can fix the switched correctly. Just make sure you don't leave the blower on all the time, it'll kill your battery.
The only reason I did this was because it was 12 degrees, snowing, when my switch broke. So the temporary fix was gold to me. Warmth is taken forgranted.
Old 04-11-2004, 09:19 AM
Okay, Thanks! I'll try it
Old 04-20-2004, 04:18 AM
tonsofunburns tonsofunburns is offline
Send a message via AIM to tonsofunburns Send a message via Yahoo to tonsofunburns
You should check the ground for the blower motor. I had a similar problem and just had to clean the ground and worked better than it ever has.
4wd hi does not work Bob miller Blazer 2 12-19-2005 07:14 PM
heat or ac does not blow out like it should wrkmn84 Camaro Discussions 1 11-27-2004 06:19 PM
88 Cherokee heater fan does not blow. 88Jeepster Cherokee 3 11-09-2004 10:16 AM
She does not blow... GMez12 Cherokee 3 07-16-2004 03:41 PM
92 grand am heat does not blow out strong jfreeway83 Grand AM 7 02-14-2004 01:31 PM
