Old 01-19-2004, 03:52 AM
jfreeway83 jfreeway83 is offline
Angry 92 grand am heat does not blow out strong
I have a 92 grand am and my heat comes out but it comes out weak and when i turn it to blow max heat you can hear it blowing like crazy but you still can barley feel the air its still weak i changed the blower but it didn't the same thing the blower seems to work but its really getting on my nerves please somebody tell me something
Old 01-23-2004, 09:50 AM
coolman2003 coolman2003 is offline
Re: 92 grand am heat does not blow out strong
i have the same problem with my car and i think that the problem is with the car computer
Old 01-24-2004, 07:16 AM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
it is not with the Computer. Your vents might be partially plugged. Or you Blend doors are not opperating properlly
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 01-25-2004, 12:43 AM
jbmx4life jbmx4life is offline
Send a message via Yahoo to jbmx4life
92 Grand Am Heat not blowing
I have the same car and had the same problem........ the problem is that the condensor is plugged up full of bug and debris that is restricting the airflow through it to go into the passenger compartment. What you have to do is take off the Air Inlet Duct....... which is the whole black thing that runs along the firewall on the engine side and then use a vaccuum and brush to suck/clean out all of the debris that is blocking the condesor. It is a real pain in the butt, but very worth the time if you want your airflow back.
Old 01-26-2004, 11:35 PM
where is the condenser located is the condenser the radiator or is it on the radiator?
Old 01-27-2004, 07:14 AM
i wrote a response to this thread yesterday but somehow it didn't show up so im writing it again. The problem might not be the ecm but the wires leading up to the ecm and u should get that checked cause my car just got out of the garage and that was the problem also i changed the thermostat and the blower fan.
Old 01-28-2004, 07:53 PM
the condensor is just behind the firewall but also behind the black air duct that the heater fan is in. In order to get to it you'll have to take the black air ducting off.
Old 02-14-2004, 01:31 PM
lgh797s lgh797s is offline
I also have a 92 Pontiac Grand Am and I am having the same problem, except for a new issue........the heater is suddenly making a loud grinding noise. Could this be related to the condenser being clogged or would is the heater motor just going out? Thanks!!
Front Heater Not Blowing Very Strong FIX ?!?! woscarr Venture 6 12-04-2007 12:16 AM
Front Heater Not Blowing Very Strong FIX ?!?! woscarr Trans Sport 4 01-22-2006 08:52 PM
heat or ac does not blow out like it should wrkmn84 Camaro Discussions 1 11-27-2004 06:19 PM
Heat and AC not blowing out budzy0844 Grand AM 4 10-12-2004 01:43 PM
heat not blowing out gadd32 Legend | RL 0 01-07-2004 09:09 PM
