Old 04-06-2004, 11:43 AM
94CamaroZ28's Avatar
94CamaroZ28 94CamaroZ28 is offline
Send a message via Yahoo to 94CamaroZ28
Ram Clutch, GM Clutch
I put in a Ram clutch into my '86 Camaro and I ended up burning it up completely in about 6 months. Next I went and purchased a high performance GM clutch. The GM clutch cost about twice as much, but sticks way better and still does about a year later. Whats up with this?... I thought Ram Clutches were the best?, or are the GM High Perfomance products really that good? Or are there any small errors that can be made installing a clutch that can cause it to burn out faster?
Old 04-06-2004, 03:49 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
well there's a few things that could cause that. could be just a bad clutch to begin with or, clutch pedal free play not adjusted right, and riding the throw out bearing causing the clutch to slip, warped pressure plate, and as i mentioned in another thread ALL FINGERPRINTS must be removed with a cleaner before assymbly. doesn't matter if you can see them or not they will burn up a clutch disk. is the rear main seal leaking on the block? engine oil will usually cause a clutch to grap really hard for a couple hundred miles before burning up the clutch. how hard did you drive the car? clutches require break in too
Old 04-06-2004, 04:05 PM
Re: Ram Clutch, GM Clutch
The rear seal on the block was not leaking, but I did drive the car pretty hard before the clutch crapped out. The thing is that the GM clutch just sticks a lot better and so far has lasted a lot longer.
Old 04-06-2004, 06:48 PM
4onFloor's Avatar
ya tend to get what you pay for. i've found that the GM replacement parts are usually better than what you get at a parts store, but also cost alot more too.
'05 Dodge Ram 1500 - Tail Lights Not Working DodgeRam1500 Ram Pickup | Ram SRT10 10 12-27-2014 12:58 AM
Clutch...clutch...clutch.... panozracing GTRA / GTWS / GTS 9 09-13-2010 08:02 AM
BREAKING: Ram HD just named Motor Trend’s 2010 Truck of the Year! RamTrucks Ram Pickup | Ram SRT10 3 12-15-2009 08:03 AM
1984 Dodge ram d50 clutch issues tommytom11 Ram Pickup | Ram SRT10 9 06-17-2008 02:55 PM
Clutch Clutch Clutch drewh4386 Off-Topic 1 09-17-2004 03:02 PM
