Old 04-06-2004, 10:21 AM
ecumatt ecumatt is offline
Send a message via AIM to ecumatt
Headgasket gone need info
the head gasket in my jdm b16a1 went bad. I was wondering if anyone has replaced theres and what they did. Does anyone know where i can find al the timing specs?
Old 04-06-2004, 11:47 PM
liquidflame8 liquidflame8 is offline
Re: Headgasket gone need info
ignition timing i would assume would be the same as the 2nd gen b16 and you can buy a manual for the motor
Old 04-11-2004, 04:52 PM
Lude_03 Lude_03 is offline
i did the head gasket on my prelude srv ( h22a1 ) it was a bitch to do but its saved me about $1500 canadain. doing a b16 shouldnt be hard just u need to basicly unbolt all the stuff on the head. i would reccomend going to honda and buying the service manual. it help me so much it has everything u need to know and shows how to remove the head and all that good shit. seeing as the head is goin to be off u should look into port and polish if your doing up the engine it helps so much... i gives you about 25% more hp
Old 04-11-2004, 05:44 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
www.helminc.com for all you automotive service manual needs.
Old 04-12-2004, 12:57 PM
I cant afford to get p/p right now. Its the first time ive had to dive into an engine so im tryin to cover all my bases. My mechanic cousin is helpin me but we needed torque specs and shit.
Old 04-14-2004, 03:20 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
if you want tourqe specs just buy a hondabuilders guide
Vehicle info needed biggie360 Shop Owner Advice 0 03-27-2009 11:12 PM
Struts Need Replacing Need Info Install brock02 Cutlass Series 2 01-13-2008 10:41 AM
need info on what ecm mods a tuboed 420a needs. rs2evo Engine, Transmission and Drivetrain 3 04-21-2007 03:32 PM
HELP!! Need to cast or mold...need info!!!! modelfreakca Car Modeling 5 03-13-2007 02:07 PM
i need help with my crx... i need info zkhan Exterior | bodykits | Lighting 2 11-27-2006 12:11 AM
