Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-20-2007, 11:27 PM
rs2evo rs2evo is offline
need info on what ecm mods a tuboed 420a needs.
o.k i'm new to imorts but not turbos. i'm a diesel mechanic and everything i work on is boosted. what i'm trying to figure out is what i need to do to the ecm to run a turbo on a 420a in a 97 rs eclipse, with an auto that is going to hit the parts bin after locating a 5 speed. the engine will be built to handle the stress of boost and my driving habits. just looking for a bone yard engine now because i enjoy driving it more than my fuel chugging gmc.
Old 04-20-2007, 11:36 PM
Re: need info on what ecm mods a tuboed 420a needs.
by the way im in harris county texas aka houston so it would be best to pass smog test. obd2 is just a plug in test to verify the system is working. any help would be appriciated thanks
Old 04-21-2007, 09:49 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Nothing needs to get done to the ECU in order to run a turbo. You just need all the supporting mods in order to keep from things such as fuel cut. No actual "mods" are need to be done to the ECU though.
Now if you're switching from auto to manual, you need a manual ECU, and drop out that auto transmission computer.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-21-2007, 03:32 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
You will need to get some kind of Fuel Cut Defender. You could either use missing link which is a mechanical device or an electronic one. which ever you prefer. Basicly you are preventing the computer from reading boost from the MAP sensor.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
