Old 04-05-2004, 06:57 PM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
Question Re: D15B - VTEC??? WTF?
I was just on (http://www.jspecjdm.net/) where it said that there are D15B-VTEC's for sale. What the hell? Is that right? A D15B VTEC? Did anyone else hear of this before, or did I just make an ass out of myself???
Old 04-05-2004, 06:59 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: D15B - VTEC??? WTF?
yes its a lil old motor I really dont think too highly of them but most who have them are fairly rabid about them.
Old 04-05-2004, 07:08 PM
GTA's Avatar
GTA GTA is offline
Whee..
its out of a jdm car, its pretty much a d16z6 but a 1.5 liter.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-05-2004, 10:24 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
It is the 1.5L VTEC (not VTEC-e, but regular VTEC) out of the JDM Civic VTi. It makes 130hp and 111 ft/lb torque, and revs stock to 8000rpm. It's a great motor and realy cheap too. It has the PO8 head, which is essentially identical to the P28 head of the D16Z6, with the P28 cam in it. It really is the least heard of but one of the best SOHC motors, if not the best, because of its high revving design. I have installed several, and they run great in the 4th gens, and can easily outdo the Z6 due to being a little lighter and having a little bit more torque and hp. I don't have one, but I'm a big fan. I can get them delivered for $525 to most anywhere you want. Two thumbs up for a well designed Honda motor!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 04-05-2004, 10:36 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
This is my JDM D15B VTEC.
All the part numbers on the head, intake manifold, and distributor match up to the D16Z6.
Only differences appear to be in the block... same bore as the Z6, but shorter stroke + smaller displacement.
Don't yet have it on the road... but hopefully by this weekend I can give some reviews on the power.
Old 04-06-2004, 09:24 AM
4GZChatch's Avatar
Tha't carzy. The ones that I have installed all had PO8 stamped on the head and intake manifold, but had the P28 cam. I guess there are different versions out there. I was told that the PO8 head was designed to flow better than the Z6 head in order to get more power out of the little 1.5L beast. The ones that I have put in had a surprising amount of power. I'm sure you'll love it, especially up from 102hp...
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 04-06-2004, 09:31 AM
Killa_CRX's Avatar
When Civics Attack!
Re: Re: Re: D15B - VTEC??? WTF?
Up from 92 actually + the direct port n2o injection kit I'm getting... why not turbo or supercharger? with gas prices rapidly aproaching $2.50 a gallon, I really can't afford to have the power all the time... power when I need it is just fine!
Boy, it's going to be strange though, going back to driving a Civic after driving my Camaro around for a year.
Old 04-06-2004, 11:28 AM
JimCRX's Avatar
JimCRX JimCRX is offline
Reason why people use this D15B Vtec 1.5l motor is because it has the 3 Stage Vtec. It adjusts in low rpms, mid rpms and high rpms. If you wanna know more check out this write up http://www.leecao.com/honda/vtec/3stagevtec.html
Old 04-06-2004, 06:16 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
i did this swap and i think something is wrong. seems like the car barely wants to go over 100, to where my dx motor with 190k would do it just fine, i have a 95 vti motor, 90si tranny, 88si ecu, and a vafc2 im using NGK sparkplugs, i have a ACT stage3 clutch, intake, headers and stock exhaust. and it seems slower... slowboycivic any help with this?
i got beat by a si swap... with pretty much the same setup cept it was a safc and he has 2.5 exhaust with a racing muffler.
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 04-06-2004, 07:37 PM
Killa_CRX's Avatar
When Civics Attack!
All 96 and later model VTEC equipted engines have this feature... but the 92-95 VTi engines that are being sold are not 3 stage vtec.
Old 04-06-2004, 07:42 PM
Killa_CRX's Avatar
When Civics Attack!
Is your vafc hooked up correctly? car running rich? did you break in the clutch before driving the car hard?
Old 04-06-2004, 09:46 PM
slyw/fbpsi's Avatar
slyw/fbpsi slyw/fbpsi is offline
The d15b vtec does not rev to 8000 rpms in stock form, it revs to 7350 is you use the p08 ecu that was made for that engine. Also, it does not have a p28 cam in it, the cam profile for the d15b vtec engine is comparable to the zex 53900 cam. But, as far as the head, yes, it is basically a d16z6 head. However, the p08 ecu gives it a slightly more aggressive fuel and timing curve than the p28. Also, with it's 1.62 rod/stroke ratio, it is the best d-series motor for revving. The vx motor has the same r/s ratio, but it is nowhere near the 130ps or 128 hp that the d15b vtec produces.
Sly
Gotta catch me first
Old 04-06-2004, 10:07 PM
Killa_CRX's Avatar
When Civics Attack!
I'm curious... where do you get your information from, good sir?
Old 04-07-2004, 06:30 AM
slyw/fbpsi's Avatar
Here: http://asia.vtec.net/article/d15b/ here: http://www.honda-tech.com/zerothread?id=585043&page=1 and here: http://www.honda-tech.com/zerothread?id=654293
Sly
d15b vtec Fuel Cutoff? markpa Engineering/ Technical 1 01-31-2004 04:40 AM
JDM d15b vtec Dumped91Hatch '88 - '91 Civic | CRX | Wagon | Shuttlee 34 12-21-2003 02:56 PM
JDM D15B vtec Dumped91Hatch '88 - '91 Civic | CRX | Wagon | Shuttlee 22 11-15-2003 07:50 PM
t3/t4 turbo on d15b vtec markpa Forced Induction 3 08-16-2003 07:31 PM
d15b vtec slowCRXinPitt '88 - '91 Civic | CRX | Wagon | Shuttlee 6 04-18-2003 11:04 AM
